AWX Piston Damage: AVF Engine Replacement
benje2
Post07-10-2008, 14:30    Subject: AWX Piston Damage: AVF Engine Replacement Quote
icon_cry.gif Now, it's "me" who's affected. My AWX engine has a hole in a piston crown, and the cylinder walls are also damaged. Since the engine now has over 200,000 km, I'm going to install an AVF engine. (AVF because it's currently available). Now, my question: Can I continue to use the engine control unit from the AWX without any restrictions or software changes?
Translated on 26-08-2026, 23:36.
benje2
Post09-10-2008, 19:47    Subject: AWX Piston Damage: AVF Engine Replacement Quote
vagtuning said the following in another thread:
For control units with the following numbers:
038 906 019 EN
038 906 019 EP
038 906 019 ER
Should the PDEs with index AL or AR be installed?
"At"
038 906 019 GT
038 906 019 GQ
038 906 019 GR
The PDEs with index BA should be used.
Does anyone have information about my car with the license plate 038 906 019 JQ?
Translated on 26-08-2026, 23:38.
benje2
Post10-10-2008, 9:38    Subject: AWX Piston Damage: AVF Engine Replacement Quote
I had the AWX with...
MSG-VAG No. 038 906 019 JQ 1570
Software version 1037, build 366047.
"Can we determine which partial differential equation this refers to?"
Is the software working?
Translated on 26-08-2026, 23:39.
mullemaus
Post12-10-2008, 13:56    Subject: AWX Piston Damage: AVF Engine Replacement Quote
'Can we determine which partial differential equation this refers to?'
From 12.2000 - PDE-P1.1/80/520 S214 or PDE-P1.1/80/520S216.
Currently, it should be VAG.
038 130 073 BA
038 130 079 F(x)
Ford:
3M21 9A543 AA
1253765
formerly:
038 130 073 AR, formerly: 038 130 073 AN - make something of it icon_wink.gif
Translated on 26-08-2026, 23:41.
audizz
Post16-10-2008, 7:08    Subject: AWX Piston Damage: AVF Engine Replacement Quote
Does the gearbox actually fit?
If my memory serves me correctly, an AWX engine always had a 5-speed gearbox, while an AVF engine had a 6-speed gearbox!
Translated on 26-08-2026, 23:42.
benje2
Post16-10-2008, 9:12    Subject: AWX Piston Damage: AVF Engine Replacement Quote
The clutch is different, but the transmission fits. I also replaced the clutch and dual-mass flywheel anyway (the AWX has less torque). GKB: GBQ.
Translated on 26-08-2026, 23:43.
No new posts Piston hole at cylinder 1 Diesel Engine Technology
No new posts Piston Hole: Causes, Repair & Prevention Diesel Engine Technology
No new posts Piston Hole: Causes and Solutions Diesel Engine Technology
No new posts VW 1Z Engine Replacement | Exchange Motor Diesel Engine Technology
