Engine Control Unit (ECU) Not Responding.
Sebikom1
Post15-10-2008, 18:23    Subject: Engine Control Unit (ECU) Not Responding. Quote
With my Audi A4 TDI, equipped with the AFN engine, I am unable to access the engine control unit, even though I was able to read it without any problems using the same hardware about two months ago.
What I need to say is that when I press the "Engine Control Unit Mileage" button, the engine control unit is found (but the mileage cannot be determined because the ECU probably doesn't store this information).
How is it that it works in one mode, but reading data is not possible?
I've also tried reinstalling VAG-COM, but it didn't help.
I have the VAG-COM/OBD2 professional diagnostic system KKL+CAN (USB).
Sebastian.
A4 B7 2.0 TDI BLB
A4 B6 1.9 TDI BKE
Translated on 06-09-2026, 7:28.
Post15-10-2008, 20:06    Subject: Engine Control Unit (ECU) Not Responding. Quote
Please describe exactly what's not working and what the error message says. Ideally, provide a Screenshot of what's working and what's not.
Translated on 06-09-2026, 7:29.
schrauber84
Karma: +1 / -1   Thank you, like it!
Post15-10-2008, 21:05    Subject: Engine Control Unit (ECU) Not Responding. Quote
Did you install an aftermarket radio? It might not be working properly because of that. You should probably try turning it off or pulling the fuse. I've had this problem before too.
Sebikom1
Post16-10-2008, 20:00    Subject: Engine Control Unit (ECU) Not Responding. Quote
I have an auxiliary radio, but even turning it off or unplugging it didn't solve the problem.
I took a couple of screenshots.
Error:
http://www.bilder-hochladen.net/files/8fmk-2.jpg
The first time you click this button, nothing happens, but on the second click, and every click thereafter, it always works.
http://www.bilder-hochladen.net/files/8fmk-3.jpg
Then comes this:
http://www.bilder-hochladen.net/files/8fmk-8.jpg
Sebastian.
A4 B7 2.0 TDI BLB
A4 B6 1.9 TDI BKE
Translated on 06-09-2026, 7:30.
No new posts Doku, n.lÜschb. Fehler im Motorsteuergerät 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts DPF not regenerating Troubleshooting & Guides
This topic is locked, you cannot edit or reply. A4 B7 Motorsteuergerät antwortet nicht On-Board Diagnostics (OBD)
No new posts Audi 80 B4 1Z: Motorsteuergerät antwortet nicht On-Board Diagnostics (OBD)
No new posts 1Z No Response: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Control Unit Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
