bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
06-01-2010, 20:28 Subject: Timing Belt Replacement: Intervals & Costs |
Hello.
How can you reliably determine the correct replacement interval for the timing belt?
Specifically, it's about a Skoda Octavia I, manufactured in 2005, with a 66kW TDI engine and a VP injection pump.
According to the workshop, the timing belt needs to be replaced at 120,000 km. However, I have often heard/read that it should be replaced at 150,000 km.
How can I find out when it needs to be done?
"Thank you."
Golf III TDI AHU 402Tkm
Translated on 23-09-2026, 17:12.
mullemaus Guest
06-01-2010, 21:47 Subject: Timing Belt Replacement: Intervals & Costs |
In the operating instructions or at the dealer  .
Translated on 23-09-2026, 17:13.
Bertil Profi-Schrauber
BennyL likes this. |
06-01-2010, 23:18 Subject: Timing Belt Replacement: Intervals & Costs |
AGP, AQM, ALH, AGR, AHF, ASV models up to May 2001 -> 90,000 km.
AGP, AQM, ALH, AGR, AHF, ASV, MJ 2002 -> 120,000 km
AGP, AQM, ALH, AGR, AHF, ASV, starting with production month 2003 -> 150,000 km.
I believe the AHF (presumably a car model) had approximately 60,000 km (or miles) on the odometer until May 2000.
Translated on 23-09-2026, 17:14.
mullemaus Guest
06-01-2010, 23:22 Subject: Timing Belt Replacement: Intervals & Costs |
AGP, AQM, ALH, AGR, AHF, ASV up to MJ 2001 -> 90,000 km.
According to my understanding, the AHF (presumably a car model) had approximately 60,000 km (37,000 miles) on the odometer until May 2000.
The 60,000 km interval was, as far as I know, only for the AJM engine.
Translated on 23-09-2026, 17:15.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
07-01-2010, 7:39 Subject: Timing Belt Replacement: Intervals & Costs |
My old A3, model year 1998, with automatic air conditioning definitely had 60,000 km on the clock, and later, with a different belt, it had 90,000 km.
Translated on 23-09-2026, 17:16.
Profile PM WWW Garage |
bindpe Blaumann
07-01-2010, 17:09 Subject: Timing Belt Replacement: Intervals & Costs |
hello
Sure, no problem.
The service booklet states the prescribed interval of 120,000 km.
Could it be that the vehicle is from an older model year? The first registration date is 2005.
Can you find out more details based on the engine number and chassis number? Or is it just a typo in the service booklet?
"Thank you."
Translated on 23-09-2026, 17:17.
07-01-2010, 17:59 Subject: Timing Belt Replacement: Intervals & Costs |
bindpe wrote: | hello
Yes... The 10th digit of the vehicle identification number (VIN)!
Translated on 23-09-2026, 17:18.
bindpe Blaumann
07-01-2010, 18:07 Subject: Timing Belt Replacement: Intervals & Costs |
"Thank you."
If I post the number, can you tell me which interval is correct?
07-01-2010, 19:16 Subject: Timing Belt Replacement: Intervals & Costs |
bindpe wrote: | thank you
Yes... If not here, then via private message... (not everyone needs to see your VIN  ).
Translated on 23-09-2026, 17:19.
