Hello!
It is about
https://community.dieselschrauber.org/en/viewtopic.php?t=20663.
I'm installing a 1995 Audi AAT engine into a different vehicle that originally had a gasoline engine. I want to eventually achieve 140 horsepower and 310 Nm of torque, but first, I want to get more torque at lower RPMs, especially below 2000 RPM. The vehicle is a small truck. I need better performance at both low and high RPMs. People often ask, "Why not just use a larger engine?" But I also need a small and lightweight engine that won't negatively impact the vehicle's weight and space.
I want to learn how the engine control unit (ECU) works, so I can understand how a performance upgrade affects it.
