Passat Tailgate Problem: Repair & Troubleshooting
Stephan_Reisch
Post27-10-2008, 10:50    Subject: Passat Tailgate Problem: Repair & Troubleshooting Quote
Hello colleagues,
I'm experiencing the usual problem with the washer nozzle rotating, and now the rear hatch won't open - the lock cylinder is corroded. Unfortunately, I can't even open the lock using the remote control either. Now I need some good advice. How can I get the tailgate open so I can fix it? I would be very, very grateful for any suggestions.
Best regards, Stephan.
Translated on 09-08-2026, 15:18.
bloesch
Post27-10-2008, 11:24    Subject: Passat Tailgate Problem: Repair & Troubleshooting Quote
While I don't have the rear door trim of a 3B in front of me right now, you'll probably need to remove it from the inside.
Translated on 09-08-2026, 15:19.
Jürgen
Post28-10-2008, 22:58    Subject: Passat Tailgate Problem: Repair & Troubleshooting Quote
'I've had this happen on my wife's Passat before. Back then, I removed all four screws – two at the top and two under the covers in the handle recesses – and then pulled back the trim as far as I could so that I could reach underneath with my hand to access the linkage of the flap locking mechanism. It's a bit fiddly; it's best to fold down the rear seat for better access. But it was actually quite quick.'
Translated on 09-08-2026, 15:20.
Stephan_Reisch
Post04-11-2008, 10:10    Subject: Resolution: Meaning and Definition Explained Quote
Hello colleagues,
'I did it! Basically, you need to access the trunk from the inside and remove the two screws located in the handle recesses. The two screws that connect the upper and lower rear door panels on the sides are not easily accessible. However, with a bit of 'force,' you can also get those out. Then, you can remove the entire paneling, allowing you to access the linkage and open the trunk. After that, I removed the lock/cylinder and thoroughly treated it with WD40. Now it works normally again. The rotating windshield washer nozzle will be addressed next year. Best regards, Stephan.'
Translated on 09-08-2026, 15:21.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Fuel Pump for VW Passat AFN Engine Diesel Engine Technology
