Vehicle: Volkswagen Golf IV Convertible, 2.0 gasoline engine.
MKB: AWG
The water temperature gauge has been malfunctioning for a few months.
You're driving, the engine is warm, and the temperature gauge reads 90°.
Occasionally, during the drive, the display will either drop to zero completely, or sometimes it will decrease to a value between zero and 90°. The speed at which the display drops is also variable; sometimes it happens as quickly as when the ignition is turned off, but other times it takes several minutes for the display to settle at the lower level.
This behavior only occurs sporadically and is not reproducible. However, the driving characteristics and fuel consumption are not affected at all when the water temperature gauge drops.
"Does anyone recognize this behavior? Could this behavior be caused by a faulty instrument cluster? I took a
Screenshot with VAG-Com about 20 minutes into a drive earlier (see attachment)."
Unfortunately, I am missing a label file for the AWG motor. In addition to the water temperature sensor, the motor also has an oil temperature sensor as standard equipment.
If the displayed 45°C were coming from the water temperature sensor, it would clearly indicate that it is defective. The 94.5° would then likely be from the oil temperature sensor. However, at that time, the combined instrument only showed 84° oil temperature. Everything is a bit strange. While the
Screenshot was being taken, the engine was idling, and the water temperature gauge was fluctuating, oscillating between 90°C and approximately 70°C.
