10-cent tuning and thrust cutoff
ewitt
Post14-11-2008, 13:35    Subject: 10-cent tuning and thrust cutoff Quote
I installed a "10-cent tuning" chip in my '94 Jetta. Is the assumption correct that a "10-cent tuning" chip distorts the signal from the RWG (rotary water pump), and therefore, even with active thrust stage shutoff, diesel fuel is still injected?
Erwin.
Translated on 11-07-2026, 7:05.
leo_b
Avatar-leo_b
Post14-11-2008, 20:30    Subject: 10-cent tuning and thrust cutoff Quote
Hi Erwin, I didn't write what's written here!
If your wiring is correct, voltage readings below 0.6-0.7 volts will not be distorted.
In this area, the MSG operates as it did before the tuning.
best regards, leo
Mein Bussi: Trapo, 7/1999, Kombi L, 8 Sitze, Indianblau, 88PS (65kW) TDI, MKB: AJT, GKB: DUJ, mit kleinem LLK, 340000km
Translated on 11-07-2026, 7:06.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post17-11-2008, 17:44    Subject: 10-cent tuning and thrust cutoff Quote
The "Ew@in" thing is a gimmick created by Rainer because he had to deal with something annoying.
Users apparently wanted to download this program for free from somewhere and were therefore asking hypocritical questions icon_wink.gif.
And as "leo b" already mentioned, this has no or only a marginal impact.
Translated on 11-07-2026, 7:07.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts Questions about 10cent Tuning {QUESTION_1} {QUESTION_2}... Diesel Engine Technology
No new posts AHF Tuning: 10 Cent Experience Report Diesel Engine Technology
No new posts Tuning: Boost Increase & Piston Failure Diesel Engine Technology
No new posts Idee : 10cent Tuning durch nachgerüstete Lambda-Sonde re... Diesel Engine Technology
