Hi everyone,
I've been desperately searching for a few days for a tip or a recommendation for a diagnostic tool for my Passat 3B TDI 85kW, manufactured in 1999, or for VWs in general up to the year 2002.
It should be suitable for all types of engines, including gasoline engines.
It's about this:
- Read and clear error codes.
- Read measurement values, for example, from the mass airflow sensor.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
to be able to
It could be something along those lines.
[VAG-VW-AUDI-CAN-BUS diagnostic interface - 2x2 COM ports]
or simply a case for a laptop, that would actually be my preference.
It should cost no more than €150-€200, but less would be even better.
I've already found one.
http://shop.dieselschrauber.de/product_info.php/products_id/36
Maybe someone has it and can tell me if it's possible to work with it effectively.
I have a laptop with USB ports, but no RS232 port.
