Help!!!! A4 B5 1.9 TDI VAG COM error code 01237
2fast_driver
Post26-11-2008, 23:02    Subject: Help!!!! A4 B5 1.9 TDI VAG COM error code 01237 Quote
I've recently been experiencing a problem where the car briefly and automatically increases the fuel supply upon starting, and then returns to idle. Performance is no longer optimal. The vehicle can only reach a maximum speed of 140 km/h.
When I read error codes using VAG-COM, the following appears:
Code:
Control Module Part Number: 028 906 021 GN
Component and/or Version: 1.9L R4 EDC G00SG 1422
Software Coding: 00002
Workshop Code: WSC 06325
1 Fault Found:
01237 - Fuel Shut Off Valve (N109)
04-00 - Mechanical Malfunction
as an error message, I deleted it, but it keeps coming back.
what can I do there?
I have an Audi A4 B5 1.9 TDI with engine code AFN, manufactured in 1997.
PS. I've been searching extensively on Google and found a R109, but I don't have a relay for it.
Many thanks in advance
2fast_driver
bastion
Karma: +6 / -1   Thank you, like it!
Post27-11-2008, 18:13    Subject: Help!!!! A4 B5 1.9 TDI VAG COM error code 01237 Quote
The fault memory already says so. The fuel shut-off valve will be defective. It is possible that they get stuck, and then an error occurs.
Use the forum search for fuel shut-off valve. The relay 109 has a different number in the B5. Search for relay 109 and Audi, there should be a thread there.
A4 Avant 08/01 AWX 05/08-
No new posts 01237 - Fuel Shut-Off Valve - Intermittent Fault On-Board Diagnostics (OBD)
No new posts Toledo TDI AFN: Error Code 01237 Troubleshooting On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. AFN glow plug blinking - error code 01237 - ignition timi... On-Board Diagnostics (OBD)
No new posts EDC login code Diesel Engine Technology
