Fuel Injector Failure: Causes and Solutions
vagtuning
Post13-11-2008, 18:44    Subject: Fuel Injector Failure: Causes and Solutions Quote
The car (A4 Limo 2.5 TDI - BDG engine) was running perfectly and could easily reach its maximum RPM until it needed to go to the workshop for an inspection. The vehicle was due for a mandatory emissions test.
and the target speed could no longer be reached - error message details are shown below.
Error cannot be deleted.
The speed is now limited to 3000 RPM, which also affects the power output accordingly.
Any suggestions?
Address 01: Engine Control Unit (ECU).
Control unit part number: 8E0 907 401 AF.
Component and/or version: 2.5L V6 TDI G000AG 0060.
Encoding: 02007
Extended information: 00008059 130 106MC318_1.V140646355
'One error found:'
01318 - Control unit for fuel injection pump (J399)
34-00 - No error type detected.
Readiness: 0 0 X X 1
Translated on 23-08-2026, 1:38.
mserge
Post24-11-2008, 16:03    Subject: Fuel Injector Failure: Causes and Solutions Quote
At first glance, I'd say the ESP (Electronic Stability Program) is malfunctioning. Check the timing belts and the diesel filter, otherwise, you're looking at a lot of money (€€€€).
Or a crumbling KAT?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 23-08-2026, 1:40.
bers
Post03-12-2008, 19:54    Subject: Fuel Injector Failure: Causes and Solutions Quote
Hi, the problem isn't with your electric pump, but rather a software error in the testing device.
Clear the error using a tester with an older software version. If that doesn't work immediately, perform a battery reset. Then, generate a new readiness code; this should resolve the issue.
Translated on 23-08-2026, 1:41.
vagtuning
Post03-12-2008, 22:02    Subject: Fuel Injector Failure: Causes and Solutions Quote
Oh, that thread still exists icon_smile.gif.
Yes, that's right, and that's all there is to it...
Translated on 23-08-2026, 1:42.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Do windows open on their own? General Tips
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine control unit destroyed during start-up On-Board Diagnostics (OBD)
No new posts Injection Pump 1Z - Buy Now! Diesel Engine Technology
No new posts Fuel Injection Pump On-Board Diagnostics (OBD)
No new posts SDI Injection Pump: Repair & Replacement On-Board Diagnostics (OBD)
