Dimensions of 1.6TD and 1.4TDI engines?
rodNeX
Post09-12-2008, 2:05    Subject: Dimensions of 1.6TD and 1.4TDI engines? Quote
Does anyone have the engine dimensions for the old VW 1.6 turbo diesel and the 1.4 PD-TDI engines?
I am particularly interested in:
The total height.
The depth (distance from the crankshaft center to the bottom of the oil pan).
Are the dimensions of the 1.9 TD engine the same as those of the 1.6-liter engine?
What other compact and affordable turbocharged diesel engines, preferably with mechanical control, are available?
I was thinking about the Fiat 1.9 TD.
Best regards, Rod.
Translated on 21-07-2026, 19:50.
Uli S.
Post10-12-2008, 12:58    Subject: Re: Dimensions of 1.6TD and 1.4TDI models? Quote
rodNeX wrote:
Are the dimensions of the 1.9 TD engine the same as those of the 1.6 engine?
Yes, in terms of the connection dimensions. The block for the 1.9 engine is 3 cm taller.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 21-07-2026, 19:52.
No new posts Passat 1.6TD to 1.4TDI Conversion Guide Diesel Engine Technology
No new posts Timing belt replacement for 1.4TDI engine. Diesel Engine Technology
No new posts Rattling noise 1.4 TDI Diesel Engine Technology
No new posts Kühlmittelstand Polo 9N 1,4TDI Hilfe!!! Diesel Engine Technology
