Cold start problem: Incorrect injection timing?
Markus H.
Post02-01-2003, 16:25    Subject: Cold start problem: Incorrect injection timing? Quote
ich habe ja seit September einen Audi 100 mit AAT-Motor im 'Fuhrpark' (s. Signature).
Since then, I've also been experiencing the following cold start problem (which I mentioned earlier).
At temperatures between approximately 5 and 10 degrees Celsius (41 and 50 degrees Fahrenheit), the engine starts without any issues (in under 2-3 seconds), but then shakes for a few seconds before abruptly settling into a smooth idle.
Today I had the diagnostic trouble codes read at a VW dealership: nothing found!
BUT I think there might be a problem with the start of injection - here are the measured values:
Ad group 0.
(Engine idling, coolant temperature not below 80 degrees Celsius)
Field 1: Motor speed - Setpoint: 43...36 - Actual: 36
Field 2: Injection start - Target: 45...60 - Actual: 39 !!!
Field 3: Accelerator pedal position - Target: 0 - Actual: 0.
Field 4: Injection amount - Target: 5...25 - Actual: 8
Please provide the text you would like me to translate from German to English.
Field 7: Coolant Temperature - Setpoint: 80...36 - Actual: 68
Field 10: Air Mass Intake - Target: 41...75 - Actual: 41
Question: So, the injection start timing is incorrect, right?
Is this therefore also the cause of the cold start problem?
Sure, here's the translation:
'Here are a few more guidelines:'
- No loss of performance.
- excellent cold start performance.
- Excellent cold starting performance even in sub-zero temperatures (with preheating).
- The timing belt was replaced during the purchase (reason?).
- hardly any soot (the 5-cylinder engines already produced a bit more soot anyway).
Thank you for your help!
P.S.:
Thanks again to MichaelII, who recently added the measurement data for the Methusalix AAT engine to the error database!
Translated on 09-07-2026, 3:20.
Andy
Post02-01-2003, 19:54    Subject: Cold start problem: Incorrect injection timing? Quote
My AFN showed exactly the same behavior before I adjusted the injection start. Take the 1.5 hours and set it up properly. You'll probably be just as excited about the starting behavior of your engine as I am right now icon_biggrin.gif.
Translated on 09-07-2026, 3:24.
christians
Post02-01-2003, 20:15    Subject: Cold start problem: Incorrect injection timing? Quote
I agree with Andy, but I also have AAT.
Gruß Christian
Markus H.
Post02-01-2003, 22:56    Subject: Cold start problem: Incorrect injection timing? Quote
Well, that's quite amusing!
Because the timing belt was replaced by the authorized dealer at the time of purchase.
Das sollten die doch eigentlich hinbekommen, ohne nochmal nachjustieren zu müssen... icon_sad.gif
Probably, a 1993 5-cylinder TDI is already considered a classic car icon_confused.gif for which no one is trained anymore.
Nevertheless, I'll let the team know about it again - it should actually be changed for free.
Translated on 09-07-2026, 3:25.
Markus H.
Post14-01-2003, 23:26    Subject: Cold start problem: Incorrect injection timing? Quote
Problem gelöst! Thank you!
Since the start of the injection process, it starts up perfectly and *runs smoothly, like a cat purring* icon_cool.gif.
Sure, this isn't exactly a groundbreaking discovery – a faulty fuel pump is bound to cause starting problems.
BUT it's perhaps interesting that it only started poorly at certain temperatures.
Normally, it would run very cleanly with good performance and be quite quiet (but now it responds to the throttle more directly).
Therefore, in such cases, don't just look for defective temperature sensors or glow plugs, but also test the fuel injection timing.
Translated on 09-07-2026, 3:26.
roter_Korsar
Post14-01-2003, 23:36    Subject: Cold start problem: Incorrect injection timing? Quote
Daher: In solchen Fällen nicht nur nach defekten Temperaturfühlern oder Glühkerzen suchen, sondern Spritzbeginn testen.
Hey,
That could be the solution to my problem. The starting behavior hasn't improved much with the new glow plugs, but it seems to prefer the stutter-free start-up (AEL) at these temperatures. According to Bosch ESi, the ESP is likely faulty or not properly configured.
Best regards from Bielefeld.
Peter.
Translated on 09-07-2026, 3:28.
haehnlein
Post14-01-2003, 23:53    Subject: Cold start problem: Incorrect injection timing? Quote
Since the start-up sequence is initiated, it starts up beautifully and *runs smoothly, like a cat purring* icon_cool.gif
Hi Markus,
I'm now starting to pay close attention icon_eek.gif icon_eek.gif. Three forum members have kindly sent me a private message, urging me to move the start date forward. Perhaps it really is the solution to my cold start problem icon_lol.gif
Wie wurde Deine Pumpe eingestellt?? Too early?
I will, however, proceed systematically: temperature sensor, flow control valve, and then the pump. I am someone who needs to understand everything icon_eek.gif. This can have its advantages and disadvantages. At the very least, I don't want to mask other causes with a premature start of the pumping process!!
Best regards, Christian.
Translated on 09-07-2026, 3:30.
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injection Start Problem: Target vs. Actual Diesel Engine Technology
No new posts Fuel Injection Timing Off? Diesel Engine Technology
No new posts Cold start problem PD AUY Diesel Engine Technology
No new posts Cold start problem 2.5 TDI V6 Diesel Engine Technology
