05-03-2009, 0:14 Subject: FSI vs. TDI: Which Engine Produces More Soot? |
Hi.
I saw a Passat 2.0 TFSI in a parking lot. It had the same exhaust pipes as mine, so I took a closer look (I ordered accessories for the 2.0 T in the US) to see if they were really the same.
I noticed that the inside of the pipes is completely covered in black soot, just like in my old Golf 2 diesel or the 3.0 TDI.
My (TDI DPF) are still so clean that you can see the seams and structures of the pipe manufacturing.
Was the TFSI engine faulty, or does it actually consume more fuel than a TDI?
Translated on 29-08-2026, 9:10.
Profile PM Garage |
Devilseye503 Guest
05-03-2009, 2:15 Subject: FSI vs. TDI: Which Engine Produces More Soot? |
'These newer FSI engines, without that strange stratified injection system, are really quite good in my opinion, thanks to the combustion process. But are they better than a TDI without a DPF? I can't say for sure - but the exhaust pipes are definitely always black.'
Translated on 29-08-2026, 9:11.
Bertil Profi-Schrauber
05-03-2009, 7:02 Subject: FSI vs. TDI: More smoke/dust? |
dieselmartin wrote: | ...
No, the box was not defective. The direct injectors are leaking!
Fortunately, this is not entirely unknown to legislators, and therefore, starting with EU5, direct injection engines must also pass a particulate matter test.
Well, and that's how even gasoline-powered cars can become fine dust emitters.
Translated on 29-08-2026, 9:12.
doppelteglasur Guest
05-03-2009, 8:17 Subject: FSI vs. TDI: Which Engine Produces More Soot? |
Interesting...
However, this would only apply to FSI systems that are operated using layer loading.
Translated on 29-08-2026, 9:13.
matthiasTDI96 Profi-Schrauber
05-03-2009, 8:26 Subject: FSI vs. TDI: Which Engine Produces More Soot? |
"But doesn't the FSI technology with stratified charge injection no longer exist?"
davidshoes Blaumann
Joined: 06/10/2002 Posts: 155 Karma: +6 / -2 Location: Sachsen
05-03-2009, 10:48 Subject: FSI vs. TDI: Which Engine Produces More Soot? |
Layered silicate materials are also not FSI (Fuel Stratified Injection) engines.
little Russian -> a lot of Russian
Gasoline PFI/MPI - Diesel DPF - Gasoline FSI - TDI
It's roughly like that, although I don't know the exact numbers right now (I'm too lazy to look them up  ).
Translated on 29-08-2026, 9:14.
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
05-03-2009, 20:15 Subject: FSI vs. TDI: Which Engine Produces More Soot? |
Two of our brand new Golf 5 company cars (TFSI models) are also emitting a noticeable amount of smoke. Besides the black puff of smoke at the start, these two vehicles also have clearly visible streaks of smoke at the rear, which forced me to get my previous car (a Suzuki Ignis DDIS) washed regularly.
Fortunately, I don't see any of that on my 206 HDI70 (with DPF, open system). In fact, the exhaust pipe on the Peugeot is almost completely clean inside. The soot deposits, at least, weren't thick enough after polishing in the autumn that you can't still see the seam of the pipe.
Translated on 29-08-2026, 9:15.
