Coolant Temp Sensor Fault: Diagnose & Repair
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Upload
haithamina
Post10-01-2009, 18:46    Subject: Coolant Temp Sensor Fault: Diagnose & Repair Quote
The temperature values from January 10, 2009, were read from the combination instrument, not directly from the engine control unit (ECU) via diagnostic trouble code (DTC) 7. Is the coolant temperature sensor defective?
On January 11, 2009, data was read from the following control units: STG Motor 3-7-10 and STG KombiInstrument 1-2-3.
"The STG control unit reported an error related to the G2 sensor and a positive voltage issue... sporadically... which could be cleared, but then reappeared on the first subsequent trip."
090111-003-007-010 & 001-002-003.xls
 File name:  090111-003-007-010 & 001-002-003.xls
 File size:  310 KB
 Downloaded:  418 times
001-002-003_20090109.xls
 File name:  001-002-003_20090109.xls
 File size:  29.5 KB
 Downloaded:  288 times
Translated on 18-08-2026, 10:16.
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Kühlwassertemp-Anzeige defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts AVF: What's wrong with it? Upload
No new posts MFA malfunction On-Board Diagnostics (OBD)
No new posts STG 028 906 021 AT defekt On-Board Diagnostics (OBD)
