Body control module, Polo 9N
Aliendrummer
Karma: +6 / -2   Thank you, like it!
Post21-12-2006, 15:58    Subject: Body control module, Polo 9N Quote
Hello everyone,
I have a question about the body control module (BCM) in the Polo 9N.
Brief background.
Since January 2006, my windshield wiper has been malfunctioning in wet weather.
He's jumping wildly between the different speed settings.
The steering wheel-mounted gear lever and the switches on the hood have already been replaced.
Last week, I took my car to the workshop to have the error codes read because the windshield wipers were acting up again... however, NO ERRORS were displayed.
The master mechanic said that the body control module is defective...
"In humid weather, moisture can seep in and potentially cause integrated circuits to short circuit..." ?!?!?!??
Shouldn't error messages be stored in the fault memory if there is a defective body control module?
Wouldn't multiple systems be affected, and not just the windshield wipers?
Does anyone have any ideas about where else I could look?
Alien drummer.
Translated on 19-07-2026, 21:31.
Post21-12-2006, 17:31    Subject: Re: Body control module for Polo 9N Quote
Aliendrummer wrote:
Since January 2006, my windshield wiper has been acting up in wet weather.
He's wildly switching between the different speed settings.
Quote: "In humid weather, moisture can get in and potentially short-circuit integrated circuits..." ???????
Typical workshop nonsense: that would be a design flaw and would have to occur on a massive scale.
Shouldn't error messages be stored in the fault memory if there is a defective body control module (BCM)?
It depends on how far the self-diagnosis goes...
Wouldn't multiple systems be affected then, and not just the windshield wipers?
It depends on the defect.
Check for chafing points in the wiring harness between the steering column switch and the BNSTG (Body Network System Transceiver Gateway), and inspect the switch itself.
Translated on 19-07-2026, 21:36.
Aliendrummer
Post21-12-2006, 18:15    Subject: Body control module, Polo 9N Quote
I suspect the problem is more likely related to the exterior area, as it only occurs in damp weather.
In the summer, I had a standard windshield wiper.
I'll still check for wear marks.
The switch is already new.
Translated on 19-07-2026, 21:40.
Aliendrummer
Post23-12-2006, 15:04    Subject: Body control module, Polo 9N Quote
I'd like to take a look at the wiring on the windshield wiper motor.
I read that problems with the limit switch on the wiper motor can cause the symptoms described above.
Do you need any special tools to detach the windshield wipers from the shaft, or is it enough to just loosen the nut?
Translated on 19-07-2026, 21:41.
Post23-12-2006, 16:51    Subject: Body control module, Polo 9N Quote
Aliendrummer wrote:
Since January 2006, my windshield wiper has been acting up in wet weather. It jumps erratically between the different speed settings.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Do you need special tools to detach the windshield wipers from the shaft, or is it enough to just loosen the nut?
You don't need to worry about this: The end switch definitely cannot change the speed (except when turning off from "fast" mode, in which case the wiper will slowly move to its final position).
Translated on 19-07-2026, 21:42.
Aliendrummer
Post23-12-2006, 17:01    Subject: Body control module, Polo 9N Quote
Okay, that was a bit vaguely worded. Sometimes it just stays on or turns on even when I haven't moved the lever.
If I move the lever down to indicate that the wiper should wipe once, it simply stays on.
Important: This only applies in wet weather!
Translated on 19-07-2026, 21:44.
rs4jackass
Post28-01-2009, 15:11    Subject: Body control module, Polo 9N Quote
Okay, here's a silly question on the side: Where can I find the body control module (BCM) in a Polo? My girlfriend has a Polo Cross, and I want to install a cruise control system in it, but I need the part number of the BCM for that.
Translated on 19-07-2026, 21:45.
Post28-01-2009, 15:35    Subject: Body control module, Polo 9N Quote
rs4jackass wrote:
Where can I find the body control module in the Polo
? It's located above the clutch pedal, after removing the lower panel.
No new posts VW T5 Interior Light/Onboard Computer Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B6 Network Control Unit Malfunction? Is a test possible? On-Board Diagnostics (OBD)
No new posts Bordnet Steuergerät: Troubleshooting After Upgrade Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi Q7: Install Body Control Module from Another Car Electrical Systems, Vehicle Electronics, Multimedia
No new posts Polo TDI: Specs, Problems, & Common Issues Diesel Engine Technology
