Fiat Ducato 2.5 TDI: Specs & Start of Production
rodNeX
Post05-02-2009, 23:14    Subject: Fiat Ducato 2.5 TDI: Specs & Start of Production Quote
'Could anyone by chance provide me with the settings for the start of the pumping process?'
Fiat Ducato 2.5 TDI, manufactured from 1994 onwards, with 85 kW / 116 PS, without AGR (AdBlue system) and without catalytic converter – is it possible to identify it?
Sure, here's the translation:
'Thank you in advance.'
Rod
P.S. By how many tenths of a millimeter can the fuel bridge actually be moved forward to achieve more power?
Something like that...?
Translated on 28-08-2026, 8:21.
vwSchrauber
Post06-02-2009, 16:35    Subject: Fiat Ducato 2.5 TDI: Specs & Start of Production Quote
Engine code?
I'll have to check that.
EDIT: I have 8140.47 and 8140.47R available.
Letzterer müsste eine Teilelektronisierte Pumpe haben. Stat. Förderbeginn steht auf 0,33 v. OT.
Beim 8140.47 1,31 v. Off-topic.
EDIT2: gerade in deiner Sig. gesehen - 116PS, also der 8140.47, Sprich 1,31 v. Off-topic.
When setting, make sure that no cold start assistance functions are active on the injection control unit! icon_wink.gif
P.S. By how many tenths of a millimeter can you actually adjust the fuel box earlier to achieve more power?
For DI engines (and that's a DI engine according to the compression ratio), I only know the value in degrees KW. I estimate it to be around 1.36-1.38, and with alternative fuels like heating oil, RME, FAME, etc., it could go up to 1.45. -without guarantee-.
Translated on 28-08-2026, 8:23.
rodNeX
Post08-02-2009, 12:20    Subject: Fiat Ducato 2.5 TDI: Specs & Start of Production Quote
Okay, that actually aligns with the data from the 'Now I'll help...' resource.
I didn't trust that copied book.
The book specifies a value of 1.31 +/- 0.05 mm.
I've modified my second Ducato to run on 1.41 [presumably referring to a specific fuel or setting].
I've had good experiences with that.
I actually might have wanted to leave even earlier.
Okay, then I'll just avoid the risk.
I've also set this to 1.41 now.
It even reached 1.50 icon_eek.gif.
And yes, that is a DI, more specifically a TDI icon_wink.gif.
Best regards, Rod.
Translated on 28-08-2026, 8:25.
vwSchrauber
Post09-02-2009, 9:40    Subject: Fiat Ducato 2.5 TDI: Specs & Start of Production Quote
Do you run it on some kind of special fuel?
Translated on 28-08-2026, 8:26.
rodNeX
Post09-02-2009, 11:38    Subject: Fiat Ducato 2.5 TDI: Specs & Start of Production Quote
No, just Diesel.
But I'm running a slightly higher LD (laser diode current), increased feed rate, and a modified LDA (laser Doppler anemometry) cone.
I always keep an eye on the water and oil temperatures.
But nothing is happening.
In my opinion, the 2.5 TDI engine has a lot of potential for tuning.
'It does have a 240 bar DÖD (good atomization), though.'
A 11mm HD component with only 116 horsepower as standard.
and all of that is spread out over 2.5 liters...
Best regards, Rod.
Translated on 28-08-2026, 8:27.
No new posts Fiat Ducato 250 2.3 D Diesel Engine Technology
No new posts Fiat Ducato Turbocharger Pressure Diesel Engine Technology
No new posts Fiat Ducato Idle Problems & Solutions On-Board Diagnostics (OBD)
No new posts Fiat Ducato and airbags On-Board Diagnostics (OBD)
