Auxiliary Heater T5: Activation Conditions Changed
Post17-02-2008, 12:36    Subject: Auxiliary Heater T5: Activation Conditions Changed Quote
The T5 vehicle automatically activates its diesel-powered preheating system at these outside temperatures until the coolant temperature reaches a sufficient level.
Da dies ja auch auf Kurzstrecke passiert, wäre ein Deaktivieren der der Heizung bei bestimmten Fahrten ja sehr sinnvoll. Leider kann der T5 das nicht über Schalter im Cockpit leisten. Bei https://community.dieselschrauber.org/en/viewtopic.php?t=20317
I only find options for unlocking and locking. I also think a permanent deactivation wouldn't be a problem. Are there any ideas on how to do that?
Translated on 03-09-2026, 8:03.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post17-02-2008, 16:49    Subject: Auxiliary Heater T5: Activation Conditions Changed Quote
My old, new idea is:
Switch the indoor control panel to "Summer" mode to adjust the settings based on the external temperature sensor.
- I did that on an Alhambra.
Edit: A permanent deactivation is not ideal via OBD, but can be easily solved using a switch.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 03-09-2026, 8:04.
Post17-02-2008, 21:47    Subject: Auxiliary Heater T5: Activation Conditions Changed Quote
Well, the goal was to avoid something like that "act of violence"...
Something else is needed.
I've had that idea before, but I don't want to solve it that way.
Translated on 03-09-2026, 8:05.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2008, 22:02    Subject: Auxiliary Heater T5: Activation Conditions Changed Quote
I already suspected that, but isn't that also "digital": on/off, finished, and that small cable, if it's connected to a nice, original switch... icon_smile.gif
Post18-02-2008, 8:42    Subject: Auxiliary Heater T5: Activation Conditions Changed Quote
Okay, I still want to get this part working like a regular auxiliary heater... maybe they're working on a solution. The frustrating thing is that it can't be turned off. The user manual says it should be deactivated using the "Econ" function of the climate control system, but that seems to be a lie... because when you open the door, you can always smell and hear the oil heater working right underneath the car!
Translated on 03-09-2026, 8:06.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post12-02-2009, 13:16    Subject: Auxiliary Heater T5: Activation Conditions Changed Quote
I noticed that the auxiliary heating function was no longer available when using the "Econ" mode in the Touran.
Translated on 03-09-2026, 8:07.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts Automatikschaltsoftware ändern?! Diesel Engine Technology
No new posts Adjust idle speed On-Board Diagnostics (OBD)
