Coolant Thermostat: Buy Online & Save!
VWGOLFIII
Post18-01-2003, 12:29    Subject: Coolant Thermostat: Buy Online & Save! Quote
Hello.
A new question I would like to ask is:
'I've noticed that when driving my car (about 10 km) in these outside temperatures (5 degrees Celsius or higher), alternating between city streets and highway (maximum 100 km/h), the coolant hose leading to the thermostat isn't getting properly warm! However, all the other hoses are at operating temperature, and the temperature gauge in the car shows 90 degrees Celsius or higher. Also, the heater gets hot when I turn it up.'
Now, to my question: Is it normal for the lower coolant hose to be colder than all the other hoses at these temperatures?
Is this due to the large radiator?
Volkswagen Golf III TD, manufactured in 1997, engine code: AAZ, 1.9L.
Thank you and best regards, Mark icon_smile.gif.
P.S. A friend of mine is experiencing the same issue. He has an Opel Astra 1.7 TD.
Translated on 02-09-2026, 14:51.
Julian
Post18-01-2003, 13:12    Subject: Coolant Thermostat: Buy Online & Save! Quote
The lower coolant hose connecting the radiator to the engine (thermostat) should remain cold (except for heat radiating from the engine). Most of the energy is used for the heat exchanger inside the vehicle, and the large cooling circuit (through the front radiator) should not be activated, therefore it should also remain cold.
The thermostat only opens and allows coolant to flow through the radiator to provide additional cooling when the coolant temperature exceeds approximately 92°C (I don't know the exact value for your specific engine).
Translated on 02-09-2026, 14:53.
VWGOLFIII
Post18-01-2003, 14:18    Subject: Coolant Thermostat: Buy Online & Save! Quote
Hello.
Thank you for your help.
Best, Mark.
Translated on 02-09-2026, 14:54.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Thermostat Replacement: Do You Need to Disassemble Everyt... Diesel Engine Technology
No new posts Oil in Coolant: Causes, Symptoms & Repair Diesel Engine Technology
No new posts Oil in Coolant B4 1Z: Causes & Fixes Diesel Engine Technology
No new posts Glow plugs for coolant Diesel Engine Technology
