tdi 1Z; Loud whistling...
dtsfreak
Post19-01-2003, 18:53    Subject: tdi 1Z; Loud whistling... Quote
Hello everyone,
For about 3 days, I've been hearing a loud whistling sound coming from the cart, and it's getting louder. My suspicion is that the problem lies with the faulty charger, as the engine as a whole appears very weak. icon_cry.gif
My question now is what kind of error message I can expect tomorrow when reading out?
This whistle gets louder and louder as the engine revs up, until you can no longer hear it. Inside, you can hear it when you're standing in front of the engine, due to the diesel fuel being injected.
I cleaned the LMM with alcohol today, but it didn't improve performance at all (which was surprising). The engine feels very sluggish overall.
Greetings
Thorsten
dtsfreak
Post19-01-2003, 20:35    Subject: DZR completed Quote
so, I've made the DZR... but I'm having trouble with it...
The time in the blue field... is that the time I should aim for? 7.368 sec?
Maybe someone (DAU) can help me...
Passat 35i; Engine 66kw/90 hp, so a 1Z; Tires 205/50 R15; Weight with me, fat coral, and everything else.. 1415 kg; Torque 202 nm; 175 km/h max speed, according to the documents.
so... in the third gear from 2000 to 4000 = 11.5 sec.
DocSnydor
Post20-01-2003, 10:23    Subject: tdi 1Z; Loud whistling... Quote
Is that a loud whistle or more of a noise?
Is your car rusting more now?
IMO, there seems to be an air leak between the intake manifold and the throttle body, or possibly a faulty air intake cooler. Therefore, check if there is any whistling sound coming from the thick pipes... This is best done with someone sitting in the car and revving the engine up to around 3000 RPM. You can also identify the leak by the presence of leaking oil...
David
No new posts Doku Transporter 7D, MKB ACV, Turbolader-Pfeifen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts lautes Brummen beim beschleunigen Diesel Engine Technology
No new posts lautes Zischen beim Beschleunigen / 2.0TDI Diesel Engine Technology
No new posts Audi A6 4B 2,5 TDI (120kw-BFC)- lautes Nagel bzw Klackern Diesel Engine Technology
No new posts HILFE Sehr lautes Nagel/Scheppern aus dem Motor?!?!? Diesel Engine Technology
