Crankshaft Bearing Caps: Damaged Threads - Mystery
roorback
Karma: +1 / -2   Thank you, like it!
Post24-02-2009, 12:23    Subject: Crankshaft Bearing Caps: Damaged Threads - Mystery Quote
hello
I have an old TDI engine block, a disassembled AEL 5-cylinder. The block itself, as well as the crankshaft and one connecting rod, are defective. I just felt like taking it apart, and besides that, some parts were needed elsewhere.
Anyway, I won't be using the block or the broken parts anymore, regardless.
Yesterday, something quite strange happened. I personally removed the brackets, or housings – or whatever they're called – that hold the crankshaft. All the screws came out normally, and I still have the screws here – they are definitely all in perfect condition and all the same length.
That's exactly why I'm now surprised that I suddenly have three defective threads on block three. The threads are stripped – so something seems to have broken off.
http://localhost.co.at/car/gewinde.jpg
It sounds really silly, but I'm extremely interested in how this could be possible - especially since I have the screws, which are okay, and I definitely didn't strip any screws during the disassembly. (screws are also visible here --> http://gallery.localhost.co.at/d/10411-2/DSC_4573.JPG))
Is there a logical explanation for this?
THANK YOU
"Hello"
Translated on 03-09-2026, 17:09.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post27-02-2009, 12:31    Subject: Crankshaft Bearing Caps: Damaged Threads - Mystery Quote
You've disassembled a motor that was previously running (in some way), I see the 5 bearing supports are detached, and you have a 5-cylinder engine? Shouldn't it have 6 bearing supports and the corresponding shells?
Then that would be 2 x 6 = 12 screws. I see 10?
Are all the screws the same length?
That would be a case for the quiz page - picture search icon_wink.gif.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 03-09-2026, 17:11.
roorback
Post28-02-2009, 8:14    Subject: Crankshaft Bearing Caps: Damaged Threads - Mystery Quote
hi
Okay, we're getting closer to the solution. There really should be 6 brackets. So, one bracket is missing, as well as one screw.
That must be the explanation; exactly three screws and one bracket are missing.
I can't believe that something like this wasn't noticed during the disassembly. However, I also didn't work very carefully myself. As I said, the engine has a connecting rod failure, and the parts, including the crankshaft, are defective. In a way, the engine block is just scrap to me.
Although the engine was technically still running, it was partially disassembled from below by a (seemingly very skilled) mechanic in order to determine the cause of the engine damage for the customer.
If this is really the case, I have no explanation for how a mechanic manages to strip three screws, while I, as someone new to this, can easily remove the other nine without any problems.
"Hello"
Translated on 03-09-2026, 17:12.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post28-02-2009, 9:53    Subject: Crankshaft Bearing Caps: Damaged Threads - Mystery Quote
I think it was different:
The engine had a connecting rod failure in one cylinder.
Either the cylinder is seized or the piston is jammed due to a blockage (possibly from the valves?).
The high force overloaded the two main bearings involved.
The screws were either elongated or broken off/damaged.
Translated on 03-09-2026, 17:14.
roorback
Post28-02-2009, 21:45    Subject: Crankshaft Bearing Caps: Damaged Threads - Mystery Quote
Okay, so the engine is supposed to have a connecting rod failure in the second cylinder, and the sheared screws are located in the center.
Translated on 03-09-2026, 17:15.
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MFA malfunction On-Board Diagnostics (OBD)
No new posts MKB: ARL PDE failure? Upload
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts LMM Failure: Troubleshooting & Repair Guide On-Board Diagnostics (OBD)
