LLT Normal: Is It Normal?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post15-03-2009, 15:25    Subject: LLT Normal: Is It Normal? Quote
hello,
Could someone please take a look at the Excel spreadsheet?
Seat Ibiza 6L, engine code ASZ, outside temperature approximately 9°C.
It seems like the LLT is very high.
Danke u. Best regards,
Jörg
The table from April 5, 2009, shows data with the new LLK system, and the outside air temperature was approximately 7°C.
LOG-01-007-011-xxx_2009_4_5_IBI_ASZ.xls
 File name:  LOG-01-007-011-xxx_2009_4_5_IBI_ASZ.xls
 File size:  9.5 KB
 Downloaded:  511 times
LOG-01-003-008-011.xls
 File name:  LOG-01-003-008-011.xls
 File size:  32 KB
 Downloaded:  379 times
LOG-01-007-011-xxx2009_03_15.xls
 File name:  LOG-01-007-011-xxx2009_03_15.xls
 File size:  20.5 KB
 Downloaded:  411 times
Translated on 14-10-2026, 0:38.
No new posts Oil in Coolant: Is it Normal? Diesel Engine Technology
No new posts Cold Start Problems: Are They Normal? On-Board Diagnostics (OBD)
No new posts Only 8 volts on the N75, is that normal??? Diesel Engine Technology
No new posts GRA Behavior in ASZ (96 kW PD) - What's Normal? Transmission, Chassis, Body & Interior
