Have the LMM repaired by VAG, but it still fails
windl
Post18-01-2003, 17:30    Subject: Have the LMM repaired by VAG, but it still fails Quote
I had my mass airflow sensor (MAF sensor) replaced because it was causing the throttle to close automatically in 5th gear at 3200 RPM. According to VAG (Volkswagen Audi Group), the MAF sensor was defective and has now been replaced. However, today on the highway, the acceleration is definitely better than before, but the throttle is again closing automatically, although only at 4000 RPM. What should I do? Well, I'll have to take it back to VAG again, but what else could be broken?
windl
Translated on 07-07-2026, 21:35.
Michael II
Post18-01-2003, 17:46    Subject: Have the LMM repaired by VAG, but it still fails Quote
Did the workshop read the error codes and perform a test drive?
If so, do you have the records?
If you happen to be there again, please make sure to refer to the aforementioned protocols before carrying out any exchange.
Tschüss
Michael II
Translated on 07-07-2026, 21:36.
windl
Post23-01-2003, 13:16    Subject: LMM Quote
It was the connector to the mass airflow sensor (MAF). Apparently, it wasn't properly clipped in. Well, it's working again now. The power feels subjectively better than before, and the top speed is just under 200 km/h without the power box, so everything seems okay. So, here's another question: Does a power box affect the lifespan of a MAF sensor?
Translated on 07-07-2026, 21:37.
Uwe
Post23-01-2003, 17:00    Subject: Re: LMM Quote
windl wrote:
So nun noch eine Frage.....wirkt sich eine Powerbox auf die Lebensdauer eines LMM aus?
...not at all!
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 07-07-2026, 21:38.
No new posts Window lifter: Repair tip for Golf IV platform Troubleshooting & Guides
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vacuum Regulator Issues: New Control Unit, Same Problem On-Board Diagnostics (OBD)
No new posts FIN: Show in Message Summary again On-Board Diagnostics (OBD)
No new posts LMM ist i.O., trotzdem Fehlermeldung Diesel Engine Technology
No new posts Diode Trick: Low LMM, Why? (SEO) Diesel Engine Technology
