Seat Leon: Disable Seatbelt Warning Light
00wumi
Post13-05-2009, 19:41    Subject: Seat Leon: Disable Seatbelt Warning Light Quote
Can someone help me turn off the seatbelt warning indicator?
I have VAG-COM 805.2 software, but I have limited experience using it.
My car is a SEAT Leon 1P.
I found something about it, but it doesn't tell me anything.
Ross Tech Support wrote:
Select STG 17 & (Combination instrument).
STG coding -> Function 07.
00??xxx: Optional equipment
+01 - Brake pad wear indicator active.
+02 - Seatbelt warning indicator active.
+04 - Windshield washer fluid level warning indicator active.
It would be great if someone could help me icon_smile.gif.
Translated on 15-09-2026, 3:39.
Back to top Profile PM Email
Post13-05-2009, 19:47    Subject: Seat Leon: Disable Seatbelt Warning Light Quote
The two ?? represent the position where the number should be inserted. If no action is required, you should enter 00. Depending on the desired action, you simply need to add up the values and enter the sum.
Sure, I understand. Please provide the German text you would like me to translate into English.
=05: is entered as a value.
Translated on 15-09-2026, 3:41.
00wumi
Post13-05-2009, 20:11    Subject: Seat Leon: Disable Seatbelt Warning Light Quote
Ah, that's something you have to add up icon_biggrin.gif.
So that I don't do anything wrong.
I selected control unit 17-Combination Instrument in VAG-COM, then went to coding-07.
There, I receive four numerical fields as output.
Encoding.
Company registration number.
Importer number.
Device number
I think coding is important for me.
Mine is 0006101.
Then I would need to subtract 02 from 06, which would give me the code 0004101. Is that correct?
Translated on 15-09-2026, 3:43.
Post13-05-2009, 21:32    Subject: Seat Leon: Disable Seatbelt Warning Light Quote
"The quick brown fox jumps over the lazy dog."
Translated on 15-09-2026, 3:44.
00wumi
Post13-05-2009, 22:17    Subject: Seat Leon: Disable Seatbelt Warning Light Quote
It worked icon_cool.gif.
Thank you for the help icon_biggrin.gif.
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts Vag-Com Codes for Seat Leon Diesel Engine Technology
No new posts Seat Leon 1P: Headlight Washer Control Time On-Board Diagnostics (OBD)
No new posts Verbrauchsanzeige anpassen Seat Leon Diesel Engine Technology
No new posts Towbar Wiring Seat Leon ST 5F 2017 On-Board Diagnostics (OBD)
