AKU 550: What to do now?
WVG
Post22-11-2005, 21:47    Subject: AKU 550: What to do now? Quote
Hello!
My second diesel engine has a problem with the number 550.
- Fuel shortage.
- Air in the fuel system.
I can rule that out.
Wenn ich den Stecker vom Nadelhubgeber abziehe bleibt der Motor stehen. I have.
I read here in the forum that the engine continues to run with the NHG disconnected. icon_eek.gif
How do I test the fuel injection start valve?
Error code: 550
Injection start control, pressure difference.
Possible causes:
Fuel injection start valve (N108) is defective.
Needle feed mechanism (G80) malfunction.
Fuel tank emptied.
Fuel supply not working correctly.
Fuel shortage.
Start of funding not in order.
Translated on 19-10-2026, 14:10.
Post22-11-2005, 22:37    Subject: AKU 550: What to do now? Quote
Take a look at the injection start timing (target vs. actual), duty cycle, and injection start timing in the basic settings mode using VAG-COM; then you should be able to clearly see what the problem is.
Translated on 19-10-2026, 14:12.
Post23-11-2005, 15:04    Subject: AKU 550: What to do now? Quote
I had an inspection with a faulty N108 sensor.
Set the basic setting to MWB 004. If that doesn't work, it's probably the N108.
/viewtopic.php?t=7709&highlight=aku+n108
I diagnosed the damage in 5 minutes, while VW then expressed the same suspicion after 45 minutes (after having checked all the TV and navigation systems in a basic Polo... or at least attempted to icon_eek.gif).
Translated on 19-10-2026, 14:13.
No new posts TDI PD: Questions and Answers Diesel Engine Technology
No new posts ...a matter of oil... Diesel Engine Technology
No new posts ahu: What is this type of ductwork? Diesel Engine Technology
No new posts Fuel Injection Pump: What Type Is It? Diesel Engine Technology
