Ford Mondeo: Won't Start After Empty Tank?
TurbochargedDiesel
Post19-05-2009, 16:39    Subject: Ford Mondeo: Won't Start After Empty Tank? Quote
Ford Mondeo 2.2 TDCi, year 2008.
The vehicle broke down while driving on the highway. The fuel tank was already on reserve. However, the display still indicated an estimated remaining range of 20km. When attempting to restart the vehicle, the fuel gauge only showed a remaining range of 2km.
ADAC determined that the fuel tank was actually completely empty, and therefore the car likely ran out of fuel.
The vehicle was refueled by the ADAC. Unfortunately, multiple attempts to start the engine were unsuccessful.
After the vehicle was towed to the workshop, the mechanic immediately checked to see if fuel was reaching the high-pressure injection pump. According to the workshop, this is the case. The mechanic also didn't have an explanation as to why the car wouldn't start despite having been refueled. He said that this needs to be investigated further.
What could be the cause?
Thank you very much.
Regards, TurbochargedDiesel.
Translated on 23-09-2026, 11:27.
mserge
Post19-05-2009, 17:17    Subject: Ford Mondeo: Won't Start After Empty Tank? Quote
Cause: Air.
Solution: Bleed.
If you're unlucky, the pump might be damaged because the parts are relatively sensitive. They are lubricated by the diesel, and if there is no more diesel and endless attempts are made to restart it, it can easily get damaged. But you still have a warranty on it icon_smile.gif.
Have you checked the manual?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 23-09-2026, 11:29.
TurbochargedDiesel
Post19-05-2009, 19:09    Subject: Ford Mondeo: Won't Start After Empty Tank? Quote
Thank you for the quick response.
You are right about the warranty icon_biggrin.gif, but unfortunately, that doesn't change the fact that the workshop itself doesn't know what's wrong.
It initially seems logical that a lack of lubrication is the cause, but wouldn't the system shut down if the fuel pump doesn't receive any diesel, in order to protect the high-pressure pump?
Translated on 23-09-2026, 11:30.
Post19-05-2009, 19:49    Subject: Ford Mondeo: Won't Start After Empty Tank? Quote
But won't the system be shut down if the fuel pump doesn't receive any more diesel, to protect the high-pressure pump?
Correct. The starting of the engine will then be prevented. icon_biggrin.gif
Translated on 23-09-2026, 11:31.
WAUZI
Post05-06-2009, 20:23    Subject: Ford Mondeo: Won't Start After Empty Tank? Quote
And what was it ultimately? As far as I know, in these cases, more than just one canister of fuel needs to be added. For safety reasons, the engine shuts off and remains in a "limp mode" until there is sufficient diesel fuel available.
Der AUDI ist weg, es lebe der KATZEN-FORD 2,0 CDTIrnrnSteuerketten find' ich geil!
TurbochargedDiesel
Post08-06-2009, 16:53    Subject: Ford Mondeo: Won't Start After Empty Tank? Quote
Oops.
Translated on 23-09-2026, 11:32.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mondeo TDCI won't start. Diesel Engine Technology
No new posts Ford Mondeo 2.0 TDCi - where to tap into the turbo boost ... Diesel Engine Technology
No new posts Jag X-Type 2.0D Turbocharger Problem? Diesel Engine Technology
No new posts Ford C-Max: Cold Start Problems & Fixes Diesel Engine Technology
