Engine Control Module Login 8E0 907 401P
mickdoohan
Post26-05-2009, 17:13    Subject: Engine Control Module Login 8E0 907 401P Quote
Hello, I have a question about the login for MSG 8E0907401P in a 2003 Audi A6 2.5 TDI, 163 hp, engine code BFC. What is the login required to adjust the adaptation channels (idle speed, air mass target value, etc.)? '12233' doesn't work.
Thank you very much for your help.
Translated on 30-07-2026, 2:14.
Wiesel
Post27-05-2009, 11:41    Subject: Engine Control Module Login 8E0 907 401P Quote
Try 26242.
Best regards, Micha.
Translated on 30-07-2026, 2:15.
mickdoohan
Post07-06-2009, 11:29    Subject: Engine Control Module Login 8E0 907 401P Quote
The login is 26262.
Wiesel
Post07-06-2009, 15:00    Subject: Engine Control Module Login 8E0 907 401P Quote
I didn't want to believe it at first... But you're right.
The login information for each box is different with every encoding.
26242, 26262, 26241, 26261.
Translated on 30-07-2026, 2:16.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Login On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Login Failed On-Board Diagnostics (OBD)
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts WFS Login: How to Access VW Services On-Board Diagnostics (OBD)
