05-10-2002, 19:45 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hello everyone.
During my first attempt to connect to my tractor using a laptop and VAGCOM, I encountered previously unknown error messages, even though the adapter test was positive.
Cannot synchronize baud rate (for the motor) or...
Too many communication errors to continue (with the ABS).
After some troubleshooting, I found that the relatively high, energy-efficient resistance values for resistors R8 and R9 were making the output transistor T1 somewhat "slow."
Replacing the components with the values specified by Noxon and Stautz (1 kOhm each) fixed the error.
Sorry to everyone who is experiencing the same problems with the 2.0 replica...
By the way, I couldn't establish a connection with version 1.1 (without the output transistor, which works perfectly on my PC) either, using a laptop: the adapter wasn't recognized.
Apparently, the PC's COM port can provide more power to the adapter. The LEDs also appear to be slightly brighter in that case.
@Rainer: I'm sending you the circuit diagrams again with the modified resistor values.
Just to be on the safe side, I'm also using 1.8 kOhms for R3, because some forum members have already experienced problems with 2.7 kOhms.
Sincerely,
Ulf.
Translated on 20-10-2026, 12:47.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
05-10-2002, 21:15 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hello Ulf,
Don't give up just yet! Upload it then.
Translated on 20-10-2026, 12:49.
Profile PM WWW Garage |
Gremlin Guest
05-10-2002, 23:21 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Don't despair...
I'm going to try putting something together next week.
CU Gremlin.
OlliP Guest
06-10-2002, 9:17 Subject: VAGCOM Adapter 2.0: Problems and Issues |
without having a good understanding of the background - and
I have absolutely no experience with those parts.
Just a quick mention of the electronics magazine 'Elektor'!
In the last issue, there was a set of instructions for building an OBD-2...
Cable included. This allows for VAG Com and more - meaning multiple functionalities.
Vehicle logs - not just for VAG!
It should include Opel, Ford, BMW, DC (presumably referring to a brand or type), many Japanese cars, and more.
it's something to address.
I haven't tried it myself - I only know about it from reading about it elsewhere.
Forums and newsgroups!
@Ulf: Maybe you should check out what THEY are doing differently!
Good luck.
Olli.
Translated on 20-10-2026, 12:51.
Gremlin Guest
06-10-2002, 13:42 Subject: VAGCOM Adapter 2.0: Problems and Issues |
I'll definitely take a look.
I already laughed my head off about ELV building regulations 10 years ago. If they're still stuck in that cheapskate mindset...
CU Gremlin.
Translated on 20-10-2026, 12:52.
06-10-2002, 18:00 Subject: Electronics Projects: DIY & Tutorials |
OlliP wrote: | without having a good background - and
Just a quick mention of the electronics magazine "Elektor"!
Cable installed.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
@Ulf: Maybe you should check out what THEY are doing differently! |
Hi Olli,
I'll definitely do that... if the product is still available.
What number is that?
Translated on 20-10-2026, 12:53.
Profile PM Garage |
Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
06-10-2002, 18:11 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hello Ulf,
The versions 1.1 and 2.0 that you suggested didn't show the breakthrough success with me either.
But I already wrote in the other thread about the changes that were necessary to get my old, underpowered mini-notebook running.
I only applied the following changes that you suggested to your original version.
Quote: |
For those who want to try it out in advance:
1. Insert an additional diode (cathode connected to R1) between pin 7 of the PC connector and resistor R1.
Insert an additional diode between OK 3 (pin 3 of the emitter) and pin 7 of the PC connector, with the cathode of the diode connected to the PC connector.
3. In parallel with the LED input of OK 3 (pins 1 and 2), connect an additional resistor of approximately 2.2 kOhms.
2. Short-circuit LED3 (and the parallel resistor R4) using a piece of wire.
If the behavior improves with this adjustment (but is not yet perfect), you can further reduce the value of R3 from 2.2 to 1.5 kOhms (1.5 kOhms is the original design value).
Reduce the value of resistor R7 to 1.5 kΩ or 1.0 kΩ.
Best regards, Georg.
Translated on 20-10-2026, 12:55.
Profile PM Garage |
OlliP Guest
06-10-2002, 20:00 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hi Ulf,
'This is the October issue!'
That part is supposed to work very well.
Furthermore, I also have a LINK here.
http://hal9000.vc-graz.ac.at/3rdfloor/projects/diagnose/Diagnose-Interface.htm
It should be quite good!!!!
'I'm writing 'it should be good' because I have no idea and only...'
I read about it!
Olli.
(by the way, 'Palatinate')
Translated on 20-10-2026, 12:57.
06-10-2002, 21:31 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Georg_G wrote: |
Hi Georg,
Does that mean your adapter, which is similar to the 1.1 version (but without extra output transistors), works on your laptop?
Translated on 20-10-2026, 12:59.
Profile PM Garage |
06-10-2002, 21:39 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hi Olli,
The drawing looks practically identical to the original Noxon part at first glance.
So, therefore, nothing fundamentally new.
Thank you anyway!
Translated on 20-10-2026, 13:01.
Profile PM Garage |
07-10-2002, 7:20 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hi Ulf,
ulf wrote: |
Hi Georg,
Does that mean your adapter, which is similar to the 1.1 version (but without extra output transistors), works on your laptop? |
Exactly that.
Translated on 20-10-2026, 13:02.
Profile PM Garage |
christians Profi-Schrauber
07-10-2002, 10:33 Subject: VAGCOM Adapter 2.0: Problems and Issues |
The October issue of Elektor explains the fundamentals of the OBD interface.
A set of instructions for construction will be included in the November issue, starting on October 24, 2002.
Gremlin Guest
07-10-2002, 17:28 Subject: VAGCOM Adapter 2.0: Problems and Issues |
I skimmed the original schematic today. Everything seems to be correct for a proper RS232 implementation.
Even with a 6V level, the optocouplers should still function well (If ≈ 5mA).
I'll measure the laptop sometime when I have the chance (as soon as the portable scope is back).
I've been envisioning a CAN interface for quite some time now...
Besides the programming effort...
'The (PCMCIA) interface cards are guarded here by large, broad-shouldered men who are armed with axes... '
800 E
I guess I'll have to go and figure things out.
CU Gremlin.
Translated on 20-10-2026, 13:03.
08-10-2002, 15:00 Subject: Electrode Adapters: Buy Now & Save! |
christians wrote: | The October issue of Elektor explains the fundamentals of the OBD interface.
A set of building instructions will be included in the November issue, starting on October 24, 2002 | .
hi
I got the October issue today.
The interface with the pre-programmed microcontroller that was announced in the preview is no longer part of my (more analog, DIY) world.
I'll leave that topic to the digital enthusiasts.
Translated on 20-10-2026, 13:05.
Profile PM Garage |
kfh Guest
04-02-2003, 22:53 Subject: Adapter: Elektor Solutions & Compatibility |
In the October issue of Elektor, the fundamentals of the OBD interface are explained.
A set of building instructions will be included in the November issue, starting on October 24, 2002.
hi
I will therefore leave that field to the digital enthusiasts.
Meanwhile, some people must have already read the November issue.
What do you think of the circuit?
Better than the tried-and-true things?
Karsten.
Translated on 20-10-2026, 13:07.
BERT Guest
05-02-2003, 9:19 Subject: VAGCOM Adapter 2.0: Problems and Issues |
Hello everyone.
I also read the Elektor article. The pre-programmed chip used there converts the OBD protocol into ASCII. However, this chip can only translate the standardized basic vocabulary according to OBD. It does not know any manufacturer-specific commands. Furthermore, for diesel passenger cars, OBD support is only mandatory from 2003.
In short: no more VAGCOM.
AST.
Translated on 20-10-2026, 13:09.
