Lupo 1.2TDI Engine: Complete Disassembly Guide
wingmaster
Avatar-wingmaster
Post19-06-2009, 19:05    Subject: Lupo 1.2TDI Engine: Complete Disassembly Guide Quote
Hi.
I have a 3L Lupo in the workshop, and it's making extremely loud clattering noises.
Is it possible to disassemble the ANY 3-cylinder engine without destroying it? I read somewhere in a VW SSP document about this engine that it has aluminum bearing caps that warp when the head bolts or nuts are loosened, and that the engine then has to be scrapped. Furthermore, the engine is supposed to have dowel pins that run from the cylinder head to the main bearing caps.
Most likely, either the piston pin boss has broken off in the engine, or there is damage to the connecting rod bearing.
The mileage is only 102,000 km.
Is it worth the effort to disassemble the engine, or would it be better to just get a replacement engine block?
Sure, here's the translation:
"Thank you in advance."
Translated on 10-10-2026, 6:45.
Post20-06-2009, 21:20    Subject: Lupo 1.2TDI Engine: Complete Disassembly Guide Quote
I've already read through that.
/viewtopic.php?t=18201
It basically contains everything you need to know.
Translated on 10-10-2026, 6:46.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 3L: Oil Leak - Engine Oily Diesel Engine Technology
No new posts Audi A4 2.0 TDI: Intermittent Starting Problems Diesel Engine Technology
No new posts Fabia: Low Fuel Rail Pressure - Troubleshooting On-Board Diagnostics (OBD)
No new posts Disassembling pressure relief valves? Diesel Engine Technology
