1.9 TDI ASV: Improve Air Intake - Tips & Tricks
Octavia_4x4
Post23-06-2009, 13:02    Subject: 1.9 TDI ASV: Improve Air Intake - Tips & Tricks Quote
As stated in this technical article: https://community.dieselschrauber.org/en/viewtopic.php?t=6593 it seems to make sense to enlarge the intake snorkel from the air filter box.
Is there anyone here who has already found a practical solution for this? I don't just want to cut off the snorkel because then it would simply draw all the water spray from the inner fender directly into the air filter. I was thinking of a pipe construction, but I'm missing the right approach.
"It would be great if someone could provide practical approaches for the following engine codes:"
ALH, AGR, ASV, AHF
Specifically referring to the Seat Ibiza, Polo 6N, 6N2, and Caddy models, all of which have the air filter housing that I use.
Translated on 07-09-2026, 3:38.
vwSchrauber
Post23-06-2009, 14:41    Subject: 1.9 TDI ASV: Improve Air Intake - Tips & Tricks Quote
In various V6 TDI engines, the intake air was partially drawn in through a snorkel and partially from the engine compartment through a second intake opening.
With proper intercooling (which the Ibiza doesn't have), it's possible to do that.
During a "weekend tinkering session" where we were experimentally pushing an ALH engine to the limits of what's possible with software, I quickly drilled a few holes with a diameter of 20mm into the lower part of the air filter housing.
The intake air temperature remained within an acceptable range despite the significantly increased charge air pressure, and as a result, the target boost pressure was regulated much more precisely in the higher RPM range.
That was a G4, not an Ibiza.
Translated on 07-09-2026, 3:40.
Octavia_4x4
Post23-06-2009, 15:52    Subject: 1.9 TDI ASV: Improve Air Intake - Tips & Tricks Quote
hello,
Yes, the article actually mentions the holes, but I'm looking for a "clean" solution and don't want to have to drill any holes.
I just checked, and there are no alternatives for the air filter housing regarding the nozzle. The only other option is the ALH/ASV engine in the Audi A3, which has a different air filter housing with an intake from the front, above the bumper... but I'm not sure if that would fit. And the cost of the materials is well over €150, because I would have to replace the entire air filter housing.
Translated on 07-09-2026, 3:41.
vwSchrauber
Post27-06-2009, 11:29    Subject: 1.9 TDI ASV: Improve Air Intake - Tips & Tricks Quote
See if you can use anything from the Cupra.
It certainly costs money, but do you want to make a meaningful change, or are you looking for a quick fix?
Translated on 07-09-2026, 3:42.
Octavia_4x4
Post27-06-2009, 18:22    Subject: 1.9 TDI ASV: Improve Air Intake - Tips & Tricks Quote
That feature only works with the Ibiza 6L model, starting from 2003.
"In my model, there wasn't a Cupra TDI option, and the Cupra gasoline engine has the same bottleneck as mine, unfortunately..."
Translated on 07-09-2026, 3:43.
No new posts Improving airflow: often pointless with TDI engines Technical Articles
No new posts Suggestions welcome... Diesel Engine Technology
No new posts Water Separators G5 3C: Improve Performance Diesel Engine Technology
