Gas Delivery Unavailable
ralfoh
Post07-06-2009, 9:44    Subject: Gas Delivery Unavailable Quote
"I've been having problems with my Audi A4 1.9 TDI 130 hp, manufactured in 2003, with 145,000 km on the clock, for the past 9 weeks. I've had to be towed by the ADAC (German equivalent of AAA) twice. Suddenly, it stops responding to the accelerator, the diesel warning light comes on, and then the ESP light also starts to light up or flash. It can still idle, but it won't accelerate. The diagnostic scan indicated a faulty accelerator pedal sensor 1 and 2. The entire accelerator pedal was replaced the first time. It worked fine for 8 weeks, then the same fault reappeared. Now, there's also an error code related to the brake light switch, which has also been replaced. Yesterday, the same thing happened again: a sudden loss of acceleration."
Where else could the error be?
Thank you in advance for your expert assistance.
Translated on 02-10-2026, 11:41.
Post07-06-2009, 10:05    Subject: Gas Delivery Unavailable Quote
What error codes were stored in the system yesterday?
It's possible that the only remaining option is to check the wiring.
Translated on 02-10-2026, 11:43.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post07-06-2009, 10:51    Subject: Gas Delivery Unavailable Quote
hello ralfoh,
The brake and clutch pedal switches should be checked for proper switching function, and it's a good idea to wiggle them to see if anything changes. Both switches must change state simultaneously.
Even a "new switch" might not be positioned correctly.
Perhaps the problem wasn't with the gas pedal, but rather that the connector was loose when someone was fiddling with it.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
ralfoh
Post07-06-2009, 11:13    Subject: Gas Delivery Unavailable Quote
Thank you for your help.
Yesterday, I drove 2km away from home and then slowly drove back, so I haven't received any error codes yet. I'll be taking the car to the workshop on Monday. Hopefully, I'll get more information then. The wiring issue was also an idea we had if it happens again. I'll keep you updated. Best regards.
Translated on 02-10-2026, 11:44.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-06-2009, 11:24    Subject: Gas Delivery Unavailable Quote
What happens if you restart it? Does it work properly for a short time?
Translated on 02-10-2026, 11:45.
ralfoh
Post08-06-2009, 13:07    Subject: Gas Delivery Unavailable Quote
After a restart shortly after that phase, the problem was still there. But this morning, on the way to the workshop, everything was fine. I'm going there now to find out what the error message is.
Greetings.
ralfoh
Post09-06-2009, 18:47    Subject: Gas Delivery Unavailable Quote
I picked up my car. There were no error messages stored. On Monday, the control unit will be removed and inspected, and the relevant connectors will be checked. Hopefully, that will help. It occurred to me that it always rained when the problem occurred.
Greetings.
Translated on 02-10-2026, 11:46.
winschrott
Post09-06-2009, 23:05    Subject: Gas Delivery Unavailable Quote
'My friend had a similar problem once. The solution was a slight amount of moisture in the throttle body/ECU connector. We just dried it out with a heat gun, and it's been fine for almost 5 years.'
The problem, among other things, is that the e-Gas operates with a very high impedance. This means that even minor influences in the wiring/connectors can lead to such errors. Incidentally, I spent a lot of time icon_smile.gif trying to find the problem and found nothing - the guided troubleshooting process apparently doesn't detect water icon_wink.gif.
Okay, so maybe first try drying out the connectors and then see what happens.
VG
Translated on 02-10-2026, 11:47.
Benni
Post12-06-2009, 13:37    Subject: Gas Delivery Unavailable Quote
Yep, moisture is a hot clue!
"In my Passat, the windshield had been replaced, but it was unfortunately not properly secured. Also, the accelerator pedal broke, and I only realized there was 10 liters of water under the carpet."
Translated on 02-10-2026, 11:48.
ralfoh
Post26-06-2009, 14:26    Subject: Gas Delivery Unavailable Quote
Hello everyone,
icon_smile.gif A week ago, the control unit was removed, and all the connections there and at the pedal switches were checked and reconnected. Currently, it is working again icon_biggrin.gif. It should stay that way, otherwise it will be replaced with a new one.
Thank you very much for your help }.
Translated on 02-10-2026, 11:49.
No new posts It is impossible to clear the error code for the V71 serv... Dieselschrauber Bar
No new posts Gas Delivery: Prices & Options Diesel Engine Technology
No new posts Delayed Gas Acceptance Diesel Engine Technology
No new posts Hesitant Gas Acceptance: Causes & Solutions Diesel Engine Technology
