Windshield Wiper Motor Malfunction
edward
Post05-02-2003, 21:55    Subject: Windshield Wiper Motor Malfunction Quote
Unfortunately, my rear wiper on my Audi 80 Avant has been malfunctioning for some time. It works fine in continuous mode (when I use the wash-wipe function), but not in intermittent mode (by briefly pushing the stalk lever backward). The motor is fine (it has been replaced), and I even tried replacing the interval relay as a test, but there's no improvement. The wiper still only makes a short movement – about two-thirds of the 'total distance' – and then stops, only to move about two-thirds across the windshield again after the next activation by the relay. So, it doesn't reach the end, and it also doesn't stay in the end position.
What could that be? Is there still a control unit in the steering column that determines the duration of the pulse?
Translated on 26-10-2026, 0:35.
eike
Post06-02-2003, 9:17    Subject: Windshield Wiper Motor Problems: Troubleshooting Quote
I suspect there is a feedback line that informs the control electronics when the end position is reached.
Could it be that this line is disconnected?
I suspect the function works as follows: When activated, a time-limited pulse is sent to the motor. This time limit is presumably to prevent the motor from burning out, for example, if the wiper is frozen. The wiper then starts moving, and a control line signals that the end position has been reached. If this line or the sensor is not working, the end position may be continuously reported, and the motor will stop after the initial pulse duration.
If the motor (with its sensor contact) and the electronics can be ruled out, I would still suspect a broken wire or a short circuit (depending on the function) in the feedback line.
Eike.
Translated on 26-10-2026, 0:37.
edward
Post06-02-2003, 12:16    Subject: Windshield Wiper Motor Malfunction Quote
Hello Eike!
First of all, thank you for the information... I hadn't even considered such a type of controller initially...
To perform the test: Would it be sufficient to simply bridge the wires from the relay (2/53 and 8/53a) to the motor? I would probably exclude the wire from the motor to ground (31), since the motor runs when it does run (meaning there's always voltage there...). According to your explanation, the wires from the switch to the relay should also not be relevant, correct?
Translated on 26-10-2026, 0:38.
Gerrit
Post06-02-2003, 21:44    Subject: Heckwischer: A German Word with No Direct English Equivalent Quote
hello
Have you checked the cables in the hinge area of the tailgate? The sound suggests that the cable for the end-of-travel switch might be broken.
gerrit
Translated on 26-10-2026, 0:39.
Back to top Profile PM Email
edward
Post07-02-2003, 10:26    Subject: Windshield Wiper Motor Malfunction Quote
No, I haven't checked it yet.
I was thinking something similar, but as I said, I thought it was unlikely that there would be a separate positioning device in the motor.
First of all, thank you for your help. I'll try to tackle the problem this weekend.
Translated on 26-10-2026, 0:40.
No new posts Windshield Wiper Regeneration General Tips
No new posts Avoid squeaking windshield wipers at the front General Tips
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 6 front windshield wipers not working, motor OK Electrical Systems, Vehicle Electronics, Multimedia
No new posts Windshield wipers needed!!!! Transmission, Chassis, Body & Interior
No new posts Disable windshield wipers!! Diesel Engine Technology
No new posts Wiper blades on Golf 4 are malfunctioning Electrical Systems, Vehicle Electronics, Multimedia
