GRA Installation Issues: Troubleshooting Guide
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Toshi
Post16-07-2009, 9:41    Subject: GRA Installation Issues: Troubleshooting Guide Quote
Yesterday, I installed and activated a GRA (Gas Recycling System) retrofit kit from VW in a Golf 4 Variant with the engine code AZD.
However, as soon as I activate the GRA (presumably a system or feature), almost all the lights on the dashboard illuminate, and the engine shuts off. It can then only be restarted by deactivating the GRA.
Once the GRA (presumably a setting or feature) is disabled, you can delete all errors without any problems, and they won't reappear as long as the GRA remains disabled.
What could be causing this? I've checked the wiring twice now, but I can't find any errors on my end.
Here's the log after turning on the GRA.
Airbags and door control units can be omitted.
Vehicle Identification Number: WVWZZZ1JZ2W166829
Mileage: 116,470 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine. Label file: RKS\036-906-034-AZD.lbl.
Part number: 036 906 034 CN
Part: MARELLI 4MV G 5164
Encoding: 00031
Operating number: WSC 70181.
WVWZZZ1JZ2W166829 VWZ6Z0A3701666
"One error found:"
18056 - Data bus drive: defective.
P1648 - 35-10 - - - Intermittent.
Readiness: 1010 0101
Address 03: Brakes. Label file: RKS\1C0-907-37x-ESP-F.lbl.
Part number: 1C0 907 379 E
Part: ESP FRONT MK60 0104
Encoding: 0011266
Operating number: WSC 01317 785 00200
2 errors found:
00778 - Steering angle sensor (G85)
004 - No signal/communication - Intermittent.
01314 - Engine Control Unit.
Address 15: Airbag Label File: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 A
Part number: 27 AIRBAG VW51 01 02
Encoding: 12855
Operating number: WSC 01317.
2 errors found:
00588 - Airbag inflator (driver side) (N95)
32-00 - Resistance value too high.
01312 - Data Bus Drive.
37-10 - defective - intermittent.
Address 17: Combination instrument
Label file: RKS\1J0-920-xx5-17.lbl
Part number: 1J0 920 806 B.
Part: COMBINATION INSTRUMENT + SPEEDOMETER. RB8 V52.
Encoding: 01113
Operating number: WSC 00000.
"One error found:"
Address 19: CAN Gateway
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001.
Encoding: 00006
"One error found:"
Address 46: Comfort System
Label file: RKS\1C0-959-799.lbl
Part number: 1C0 959 799.
Component: 1F Comfort Device HLO 0001.
Encoding: 00259
Part number: 1C1959801A
Component: 1F TÔrsteuer.FS KLO 0003.
Part number: 1C1959802A.
Component: 1F Throttle control.BF KLO 0002
Part number: 1C0959811A
Component: 1F Throttle control.HL KLO 0002
Part number: 1C0959812A.
Component: 1F Throttle Control.HR KLO 0002
No errors found.
"Ende" translates to "End" in English.
Please provide the text you would like me to translate from German to English. I will do my best to provide a quick translation.
Best regards, Biggy.
Translated on 03-09-2026, 4:36.
Back to top Profile PM Email
Post16-07-2009, 9:53    Subject: GRA Installation Issues: Troubleshooting Guide Quote
I think something might be wired incorrectly... what about the single cable from the GRA that connects to +12V?
Translated on 03-09-2026, 4:44.
Toshi
Post16-07-2009, 9:59    Subject: GRA Installation Issues: Troubleshooting Guide Quote
It is located in the fuse box, as described in the instructions.
Translated on 03-09-2026, 4:45.
Post16-07-2009, 11:27    Subject: GRA Installation Issues: Troubleshooting Guide Quote
However, as soon as I activate the GRA, almost all the lights on the control panel light up, and the motor shuts off. It can then only be restarted by deactivating the GRA.
Octavia_4x4
Post18-07-2009, 21:09    Subject: GRA Installation Issues: Troubleshooting Guide Quote
Have you definitely connected the 4 pins that go to the engine control unit correctly? Was the GRA lever intended for vehicles with ESP?
As far as I can see, there's no ADZ engine code available, but there is an ASZ, a 96 kW / 131 PS TDI. Is that the one you have?
If so, please check it according to the following wiring diagram:
(1) SET switch (E227) GRA (red/yellow) T10S/3 (which is pin 3 of the GRA connector) >>> Engine control unit T121 / pin 44.
(2) GRA lever (E45) T10S/5 (white) >>> Engine control unit T121/46
(3) GRA lever (E45) T10S/2 (blue) >>> Engine control unit T121/45
(4) GRA lever (E45) T10S/6 (black/blue) >>> Terminal 147, ignition.
(5) GRA lever (E45) T10S/7 and GRA lever (E45) T10S/4 >> connected to engine control unit T121/14.
Hopefully, this helps you with troubleshooting.
Translated on 03-09-2026, 4:47.
vagtuning
Post18-07-2009, 22:00    Subject: GRA Installation Issues: Troubleshooting Guide Quote
He also wrote AZD and not ADZ - although both license plate codes exist icon_wink.gif.
ADZ is the old 1.8-liter gasoline engine from the Golf 3 / successor to the ABS, and a successor to the well-known and popular RP engine icon_wink.gif.
and AZD is the 105 hp 1.6-liter gasoline engine from the Golf 4 icon_wink.gif.
Translated on 03-09-2026, 4:49.
Octavia_4x4
Post19-07-2009, 10:42    Subject: GRA Installation Issues: Troubleshooting Guide Quote
Ah.
Then I must have missed it. Please delete my previous post, as it refers to the ASZ 1.9 TDI.
Excuse me icon_smile.gif.
Georg.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LD Increase Problems? Troubleshooting Guide. Diesel Engine Technology
No new posts Diagnosis Problems: What to Do Next On-Board Diagnostics (OBD)
No new posts Probleme nach Kennfeldoptimierung Diesel Engine Technology
No new posts Camshaft Replacement Problems: AKE Issues. Diesel Engine Technology
