Performance issues during starting
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
martin87
Post27-07-2009, 23:03    Subject: Performance issues during starting Quote
Hello!
I've been having a problem with my 3er Golf TDI (1Z) recently. When I need to accelerate a bit in certain traffic situations, it almost stalls, doesn't respond to the gas pedal for about 2 seconds, and then revs up smoothly again. This only happens when I quickly release the clutch pedal and press the gas pedal at the same time. Otherwise, there are no other issues. Could the LMM (lambda sensor) possibly be weak? VAG COM is present.
Thank you for your help,
Best regards, Martin
Post28-07-2009, 7:28    Subject: Performance issues during starting Translating...
[Translating...]
martin87
Post28-07-2009, 10:08    Subject: Performance issues during starting Translating...
[Translating...]
Ja das ist mir klar, Fehlerspeicher ist eh leer. Was sollt ich denn genau anschauen? Beim Wegfahren einmal mitloggen? Welche MWB?
Danke, grüße Martin
No new posts A4 1,9 TDI Motor ruckelt beim Anfahren wie rupfende Kupplung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 TDI ATD: Engine Noise When Starting Diesel Engine Technology
No new posts "4B AFB preheating indicator flashes during startup." Diesel Engine Technology
No new posts DSG: Kupplungssteuerung beim Anfahren und im Leerlauf Transmission, Chassis, Body & Interior
No new posts Schlag auf Achse beim Anfahren (Audi 80 B4) Transmission, Chassis, Body & Interior
