Hello everyone,
"For the past few days, I've been intermittently encountering the following error in the MSG."
Code: |
19586 - Abgasrückführsystem Regelgrenze überschritten
P3130 - 35-10 - - - Sporadisch
After being disabled, the MKL turns off and then reactivates after some time with the same error code (FC).
When I read measurement block 3, I get the following result at idle:
MAF (specified): 280.0 mg/R
MAF (actual): 475 mg/R
EGR duty cycle: 79.7%
Is it normal for the specified and actual values to deviate so much? They seem to be getting closer. Does this indicate a faulty EGR valve? I'm just wondering why the error isn't being directly registered.
I have already visually inspected the hoses. They were all okay. The only thing that surprised me was the amount of oil I saw in the air intake hose, right before the throttle body/EGR valve. Is that normal? Could it also be related to the mass airflow sensor (MAF)?
Do you have any ideas about what to do? I don't know what I need to look for...
Thank you for your help!!
