ABS Alarm System: What You Need to Know
hanys
Post28-07-2009, 7:02    Subject: ABS Alarm System: What You Need to Know Quote
Hello everyone!!!
In my Sharan TDI 110 HP, manufactured in 1998, the ABS warning light has been on since yesterday icon_sad.gif.
Does anyone have any experience with ABS?
The fuse is fine, and the brake fluid level is correct.
hobbyschrauber
Translated on 28-08-2026, 23:07.
Post28-07-2009, 8:25    Subject: ABS Alarm System: What You Need to Know Quote
Read the error codes. It could be many things, probably a sensor issue. Guessing won't help.
Translated on 28-08-2026, 23:08.
Post28-07-2009, 21:35    Subject: ABS Alarm System: What You Need to Know Quote
My 2008 Passat 2.0 TDI hasn't started since yesterday.
There's still some fuel in the tank, and the battery is also fully charged.
Does anyone know about cars and can tell me what this is?
I'm sorry, but I just couldn't resist.
I hope you understand from the example what Mathias meant. There are simply too many possibilities to consider, but the sensors are probably the most likely cause. However, to determine which one, you need to - as Mathias correctly pointed out - read the error codes.
Post29-07-2009, 7:31    Subject: ABS Alarm System: What You Need to Know Quote
guste100 wrote:
...Mathias, correctly spelled...
Translated on 28-08-2026, 23:09.
hanys
Post03-08-2009, 21:47    Subject: ABS Alarm System: What You Need to Know Quote
Okay, that's what I'll do. First, I'll check the error codes, and then we'll see what's next.
Thank you for all the answers.
hobbyschrauber
Translated on 28-08-2026, 23:10.
No new posts Golf 4 Alarm: Door Open Issue? Transmission, Chassis, Body & Interior
