Are latent heat storage systems still in use? Experience values?
CheBu
Post08-11-2004, 17:38    Subject: Are latent heat storage systems still in use? Experience values? Quote
Hello everyone,
Are there any sensible alternatives to a space heater currently available? I'm less concerned about the comfortable temperature inside the car, but rather about the engine's starting temperature.
Does anyone have experience with heat storage, or are these parts no longer available?
Thank you.
Stefan
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post08-11-2004, 17:45    Subject: Are latent heat storage systems still in use? Experience values? Quote
So, in the 5-series MBW model E-39, these things were available for a maximum of 2 years, and then they disappeared. Reason
1. These things often leaked, causing wet feet.
2. The switches, valves, and thermostats that were inside were very often faulty.
3. Doesn't help at all for short distances.
4. And so, the engines didn't get much warmer as a result.
5. The container will also only be lukewarm after 2 days.
B.Eng (FH) u. KFZ Meister
Post08-11-2004, 17:51    Subject: Are latent heat storage systems still in use? Experience values? Quote
ad 1.
Not only wet feet, the salt (Barium Chloride ??), used in it, has over time corroded and eaten into the engine due to the container.
(that's what I heard)
powermac
Post08-11-2004, 19:11    Subject: Are latent heat storage systems still in use? Experience values? Quote
ad 1.
As far as I know, a different type of salt is now being used. icon_question.gif
There is also a short article in the Autobild magazine in the supplement.
Look.
http://www.waermespeicher.com
MWeid
Post09-11-2004, 7:56    Subject: Are latent heat storage systems still in use? Experience values? Quote
Look at you
is indeed interesting! Could it be that the company is still stuck in the past? DM Prices icon_exclaim.gif
Does anyone have experience with these types of storage?
Greetings,
Mathias
Gremlin
Post09-11-2004, 8:51    Subject: Are latent heat storage systems still in use? Experience values? Quote
I invested 400 DM back then, and the Webasto is still working perfectly...
because I had to scrape ice, which still meant...
I only have the information that has already been posted:
short-term memory, not suitable for short distances ...
See you, Gremlin
CheBu
Post09-11-2004, 13:43    Subject: Are latent heat storage systems still in use? Experience values? Quote
I called there once. They are still in business.
With the universal mounting kit, such a part costs 560 EUR.
I would like it because of the easier installation compared to a
"interested in"
Let's see...
Thank you and best regards.
Stefan
Julian
Post09-11-2004, 14:51    Subject: Are latent heat storage systems still in use? Experience values? Quote
Additionally, there are stress fractures in the engine block, as hot coolant quickly passes through the (normally) very cold engine.
560€....an SH-installation is also not much more complicated and has significantly more practical value than this 'thermos flask'.
No new posts TDI Wastegate: Available engines besides the 1.4? Diesel Engine Technology
No new posts Thermal Energy Storage Centaur VW Diesel Engine Technology
No new posts Hoping for practical experience Diesel Engine Technology
No new posts 10 Cent Coin: Experience & Value Insights Diesel Engine Technology
