Auxiliary heater fuse in a VW Golf V, where is it located?
Thomas K.
Post13-08-2009, 14:59    Subject: Auxiliary heater fuse in a VW Golf V, where is it located? Quote
'Does anyone happen to have a circuit breaker schedule that shows which circuit breaker controls which electrical device?' Who is responsible for the PTC heating elements?
I couldn't find anything useful, despite searching extensively on Google.
While installing a hands-free system, I noticed that the cables to the PTC heating elements appear to be getting quite warm, so I'd like to disconnect the auxiliary heater for now.
The vehicle is a Volkswagen Golf V 2.0 TDI, engine code BKD, manufactured in March 2005.
Translated on 04-07-2026, 19:59.
tdi-erwin
Post17-08-2009, 16:11    Subject: Auxiliary heater fuse in a VW Golf V, where is it located? Quote
Hello Thomas,
According to. Until October 2005, the fuse was located at position 5 (SA 5) on fuse carrier A.
Starting in November 2005, fuse 6 (SA 6) is also located on fuse holder A.
Best regards.
TDI-Erwin.
Translated on 04-07-2026, 20:00.
Post17-08-2009, 16:14    Subject: Auxiliary heater fuse in a VW Golf V, where is it located? Quote
SA is the electronic control unit (ECU) located in the engine compartment - to the right of the air filter, next to the battery.
Translated on 04-07-2026, 20:01.
Thomas K.
Post18-08-2009, 10:25    Subject: Auxiliary heater fuse in a VW Golf V, where is it located? Quote
...I found the fuse and removed it. It worked.
Thank you again for the help icon_biggrin.gif.
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV - Climatronic not working - Fuse S180 Transmission, Chassis, Body & Interior
No new posts Glow Plug Replacement Audi A6 C4 AEL Diesel Engine Technology
No new posts G3: Mysterious Security & Vacuum Issues Transmission, Chassis, Body & Interior
No new posts 80A Sicherung unter Amaturenbrett??? On-Board Diagnostics (OBD)
