bernie123 Blaumann
19-09-2009, 20:15 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
Hello forum,
I'm looking for a checklist that can help narrow down the problem mentioned above.
Thank you in advance.
bernie
Translated on 04-09-2026, 8:02.
19-09-2009, 23:54 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
Point 1: Acquire a VAG-COM device.
Point 2: Read error codes.
Point 3: Post error messages here.
Without that, there are a thousand possibilities for what it could be. You need to have a general idea of the direction it's heading in. MfG. Michael
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
20-09-2009, 12:06 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
... and please specify the engine code or at least the power output, as different turbochargers are installed.
Also, whether the car has been modified or not, and exactly when the problem occurs.
Translated on 04-09-2026, 8:03.
Profile PM WWW Garage |
bernie123 Blaumann
20-09-2009, 12:20 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
Hello everyone,
So, the MKB is essentially the AMF without any modifications or tuning.
I'm currently checking under the car, more information will follow.
hello
there's bernie.
Translated on 04-09-2026, 8:04.
21-09-2009, 11:08 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
So, wastegate turbocharger.
How do you _know_ it's the turbo?
What about this option?
The mass airflow sensor is fluctuating, reporting insufficient airflow, which is causing the fuel injection quantity to be reduced via the opacity lookup table.
m; Transparency, Teamwork
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
21-09-2009, 13:11 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
"Haha, our A2 used to have that problem too... although it was a persistent issue until I could find a parking spot. It ripped the clamp off the LD hose right at the turbocharger. The remains were completely rusted. It was a great defect, happening right in the middle of the night in the middle of nowhere... *yes, praise be, the beloved A2, it was a great car*."
Translated on 04-09-2026, 8:05.
bernie123 Blaumann
21-09-2009, 20:51 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
Okay, so I checked the clamps and hoses, and the intake on the turbocharger is a bit oily, which might be coming from the valve cover gasket. I'll get the error codes read.
Somewhat off-topic: Is it possible to deactivate the EGR system when using an AMF (Abgasmanagement-Filter)?
"Bernie asks."
Translated on 04-09-2026, 8:06.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
21-09-2009, 21:29 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
@martin: LMM kommt eher nicht direkt in Frage. Der wird nur zur Steuerung der AGR verwendet. Thankfully!
But the rest is correct. First, read the error codes, then proceed.
Yes, AGR can be put on hold. If there's no MIL, it's possible. Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 04-09-2026, 8:07.
durnesss Guest
25-09-2009, 13:31 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
It's not uncommon in the A2 category; check out the A2 forum.
Most often, it's a loose or cracked hose in the compressed air system.
Then an error: 'Rule limit exceeded, temporarily.'
It must be stored in the MSG.
It then goes into emergency mode with very little power, and the maximum speed is approximately 110 km/h.
After the restart, everything seems to be working fine again.
Until more than ~5 seconds of power is required, it reverts to emergency mode.
Friendly people often enjoy playing games like 'Werewolf' or engaging in activities where they exchange items.
which is somehow related to the boost pressure control system.
Thomas.
Translated on 04-09-2026, 8:08.
Diesel_Rudi Guest
28-09-2009, 19:17 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
I suspect that the nitrite coating on the guide vane assembly is worn out. This often causes problems. Cleaning the exhaust side only provides temporary relief. Therefore, the best solution is either a good used part or a new one.
Regards!
Translated on 04-09-2026, 8:09.
28-09-2009, 19:36 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
The AMF turbocharger uses a wastegate system, as mentioned above. So, it's not a variable geometry turbo (VTG). Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 04-09-2026, 8:10.
Diesel_Rudi Guest
28-09-2009, 19:58 Subject: Turbo Problems Audi A2 1.4 TDI - Intermittent Issues |
He's right. I just checked on eBay. Sorry.
