1.9 TDI Head on 2.0 TDI Engine Conversion
winnie4get
Avatar-winnie4get
Post11-05-2009, 21:00    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
Hello, I would like to know if the cylinder head from a 1.9 TDI ATD engine will fit on the block of a 2.0 TDI BMM engine, including all related components such as mounting brackets and engine mounts, etc.
Best regards, Winnie.
Translated on 26-07-2026, 10:46.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post12-05-2009, 8:44    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
The BMM is a 16V engine.
The ATD has a voltage of 8V.
Nothing fits! / Nothing makes sense! / It doesn't fit at all!
Translated on 26-07-2026, 10:47.
winnie4get
Avatar-winnie4get
Post06-09-2009, 11:22    Subject: 8V vs 16V: Does DPF Matter? Quote
It's been a long time!
Hmm, I'm surprised. The BMM engine with a DPF has 8 valves, while the BMN engine with a DPF has 16 valves.
Okay, now it should be correct!
Post07-09-2009, 8:29    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
Winnie.
Please read your answer again because it contradicts itself.
And even if you replace an "without" with "with DPF" somewhere, I bet that a BMP file will result when using a DPF icon_wink.gif.
Translated on 26-07-2026, 10:48.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post07-09-2009, 8:47    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
Hi, that's how I understand it too.
"8-valve engines with DPF (Diesel Particulate Filter) tend to have worse performance."
16 valves are already better from the factory.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 26-07-2026, 10:49.
Tagessuppe
Post07-09-2009, 12:16    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
It's just a guess, but perhaps the 8V configuration was chosen for the DPF because one exhaust port heats up faster than two, which would bring the DPF to operating temperature more quickly.
This was at least practiced in this way by Deutsche Bahn (DB).
Translated on 26-07-2026, 10:50.
Post07-09-2009, 12:37    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
And with the BMR (16V PPD DPF), they then disregarded thermodynamics icon_wink.gif.
My guess is that it would be better to experiment with separating the 16V system from the DPF.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-09-2009, 12:43    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
Hmm, my guess is that when the 8-valve engine was due for a DPF (Diesel Particulate Filter), the 16-valve engine hadn't yet been developed with a DPF, so adapting it to the 8-valve engine was available more quickly.
Back then (I remember a G4), it was only available with an 8V engine and a DPF, while the 16V version was only offered without a DPF. I no longer remember the model codes.
Translated on 26-07-2026, 10:51.
Post07-09-2009, 15:00    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
That was the case with the 140 series until they were replaced by CR models.
Only the 170 hp engine was always equipped with a 16-valve DPF system.
Translated on 26-07-2026, 10:52.
Tagessuppe
Post07-09-2009, 17:03    Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion Quote
That was all there is to it.
Meanwhile, Mercedes has also managed to produce low-emission engines with four valves.
Translated on 26-07-2026, 10:53.
No new posts Headaches: Causes, Treatment & Relief Diesel Engine Technology
No new posts AJM: Headaches and Cracks in the Mind Diesel Engine Technology
No new posts AAZ block, JX head, is it possible? Diesel Engine Technology
No new posts Bosch VP37 Injection Pump Head Diesel Engine Technology
