ESP 1.9D no longer boosts after assembly!!
lothi7
1993 Renault 12
Post31-08-2009, 16:06    Subject: ESP 1.9D no longer boosts after assembly!! Quote
Hi, I installed a 1.9 diesel engine with 54 horsepower from a Renault Rapid into my boat, and my problem is that the fuel pump isn't working anymore. I had to disassemble it because the engine had been sitting for 3 years and the pump was completely clogged. I've taken the pump apart twice now and haven't found anything wrong. I urgently need help icon_rolleyes.gif icon_rolleyes.gif.
The pump is a Bosch VER588.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post31-08-2009, 21:15    Subject: ESP 1.9D no longer boosts after assembly!! Quote
Did you also clean the wing cell pump?
lothi7
1993 Renault 12
Post31-08-2009, 21:43    Subject: ESP 1.9D no longer boosts after assembly!! Quote
Sure, twice. "Is it possible that the problem is due to the overflow pipe being too large? icon_rolleyes.gif"
Tagessuppe
Post01-09-2009, 10:22    Subject: ESP 1.9D no longer boosts after assembly!! Quote
Do you mean the return line?
And why are you opening two threads on the same topic?
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pumpe fördert nicht nach Abdichtung On-Board Diagnostics (OBD)
No new posts Engine (SDI) Won't Start After Tuning! Diesel Engine Technology
No new posts 1.7L TDI Racing Engine No Longer Runs After Winter Break Diesel Engine Technology
No new posts Engine won't start - after PDE replacement Diesel Engine Technology
