Long Life Service: Your Car's Extended Warranty
150d
Post11-04-2010, 16:49    Subject: Long Life Service: Your Car's Extended Warranty Quote
My Golf IV is due for another service again – the service indicator has been nagging me for quite some time now. I always have it done at the workshop.
I've repeatedly read that it's possible to accidentally or unintentionally set a "longlife" vehicle (like mine) to a non-longlife interval. After the service appointment, can I use VCDS to check if the workshop correctly reset this setting?
150d
Translated on 18-08-2026, 12:42.
Post11-04-2010, 16:56    Subject: Long Life Service: Your Car's Extended Warranty Quote
Okay.
Translated on 18-08-2026, 12:43.
150d
Post11-04-2010, 16:59    Subject: Long Life Service: Your Car's Extended Warranty Quote
matthiasTDI96 wrote:
yes.
"Thank you, that helps me."
How?
Translated on 18-08-2026, 12:44.
Post11-04-2010, 17:37    Subject: Service Longlife Quote
/viewtopic.php?t=3139&highlight=service+interval
150d
Post11-04-2010, 17:49    Subject: Service Longlife Quote
Thank you, I have already found this page, but I am not sure if I am interpreting it correctly. Does this mean that for my gasoline-powered car, I need to check that...?
K43 = 30 (-> 30,000 km until next oil change).
K44 = 720 (-> 720 days until next oil change)
K45 = 2 (-> Oil quality code)
...and are things set up exactly like that?
Conversely, especially when...
K45 = 1
"... then was the "non-longlife" service indicator reset simply by writing to memory location K2?"
Translated on 18-08-2026, 12:45.
Malte1408
Post11-04-2010, 19:25    Subject: Long Life Service: Your Car's Extended Warranty Quote
That's all documented now in the label files of VCDS icon_question.gif.
So, the adaptation channels are now quite well documented.
Translated on 18-08-2026, 12:47.
150d
Post11-04-2010, 22:17    Subject: Long Life Service: Your Car's Extended Warranty Quote
Well, if you happen to be there, it might be okay. But if you don't even know where you need to go in the first place, and then you have four options to choose from, and each of those options...
Whatever. If that's the case, then I understand.
Thank you.
Translated on 18-08-2026, 12:48.
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Longlife Service: Every 15,000 km? On-Board Diagnostics (OBD)
No new posts Audi A6 Longlife Service: Anzeige Problem On-Board Diagnostics (OBD)
No new posts Reset Service Light: Won't Turn Off? On-Board Diagnostics (OBD)
No new posts Longlife III Diesel Engine Technology
