T4 ACV power shortage
patras
Avatar-patras
Karma: +6 / -3   Thank you, like it!
Post19-04-2010, 11:34    Subject: T4 ACV power shortage Quote
Hello everyone,
Perhaps you can help me with the following problem:
Power loss across the entire speed range.
T4, ACV engine, manufactured in 1997, approximately 185,000 km.
AGR decommissioned, Kat removed.
Standard tests were conducted.
You will find 2 log files attached, each starting at 2000 rpm in 4th gear. Speed up the process on the same track.
The 2nd. The log was processed using a different LLM.
From my perspective, the boost pressure and MAF sensor readings don't seem particularly unusual. What I'm curious about is why the driver's requested power is always being limited by torque limitation and other factors.
Maybe you have a tip for me.
Thank you.
Willi.
LOG 19.04.10.xls
 File name:  LOG 19.04.10.xls
 File size:  35 KB
 Downloaded:  608 times
Geht ned gibt´s ned!!
Post19-04-2010, 11:50    Subject: T4 ACV power shortage Quote
A dead rat under the gas pedal?
Or the doormat?
Does the accelerator pedal dead zone reach 100%?
patras
Avatar-patras
Post19-04-2010, 11:56    Subject: T4 ACV power shortage Quote
Mea Culpa,
I will watch it tonight.
Thank you.
Willi.
Post19-04-2010, 11:57    Subject: T4 ACV power shortage Quote
I agree with Martin on that.
patras
Avatar-patras
Post19-04-2010, 11:59    Subject: T4 ACV power shortage Quote
My mistake as well, of course, T4.
Damn number system!
matthiasTDI96 wrote:
I've updated it in the title and the original post.
I completely missed that.
patras
Avatar-patras
Post21-04-2010, 14:13    Subject: T4 ACV power shortage Quote
Hello everyone,
Unfortunately, my antique notebook has stopped working; the results will follow shortly.
Willi.
patras
Avatar-patras
Post24-04-2010, 9:35    Subject: T4 ACV power shortage Quote
Hello everyone,
Here's the solution:
The throttle position sensor only reached approximately 80% of its expected value in the diagnostic test.
After I installed it, the log showed... (1. During a test drive, there was a significantly higher driver demand, but the turbidity value came into play, which actually meant that no noticeable increase in performance was achieved.
Before the 2nd. During a test run, the mass airflow sensor (MAF) was replaced, which noticeably improved performance.
Okay, please provide the German text you would like me to translate into English.
LOG-01-003-008-012.xls
 File name:  LOG-01-003-008-012.xls
 File size:  30.5 KB
 Downloaded:  512 times
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G4 ALH: Troubleshooting Performance Issues Upload
No new posts G62: Troubleshooting Performance Issues Diesel Engine Technology
No new posts A4 2.5 TDI BDG - Power Loss/Performance Issues Diesel Engine Technology
No new posts T5 Engine Problems: Troubleshooting & Solutions Upload
