Replacing the combination instrument in an A6
avoso
Post12-02-2003, 19:14    Subject: Replacing the combination instrument in an A6 Quote
What should I consider if I want to install a different, but functionally equivalent, instrument cluster? I heard that you have to adjust the WFS, is that true?
The car is an A6, type 4B.
Thank you and best regards.
Okay, here's the translation:
Achim.
GarfieldMZ
Post13-02-2003, 0:51    Subject: Subject: Replacing the instrument cluster in an A6 Quote
Hello Achim!
I replaced mine last year because the display on the FIS was slowly dissolving (a problem in the model year 98)). As far as I know, you have to be careful whether you're installing a combination instrument with or without a CAN bus (up to model year 00 without CAN bus). The actual replacement itself is child's play. However, as you suspected, you need to adjust the WFS. You can only do this yourself if you have the code. Otherwise, just go to your Audi workshop; they can request the code and adjust the WFS accordingly. I had already removed the combination instrument and then went to Audi. They connected the new one and made the necessary adjustments. I then installed it myself. It cost around 20 euros.
DENNIS
Achim
avoso
Post13-02-2003, 4:19    Subject: Replacing the combination instrument in an A6 Quote
Hi Dennis, thanks for your quick reply!
Somewhere, I read that it's possible to read a 15-digit code using VAG-Com, which Audi uses to generate the 7-digit immobilizer code? Is that so?
Does this have anything to do with the code that comes with my spare key?
Best regards, Achim.
GarfieldMZ
Post13-02-2003, 7:57    Subject: Replacing the combination instrument in an A6 Quote
Hello Achim!
I'm not entirely sure anymore, but I think it's the 7-digit code on the spare key (is it possible to retrieve it?). But I'm not absolutely sure about that, either!
'In any case, Audi generates the correct code from the serial number of the instrument cluster. Unfortunately, I can't tell you exactly how to use this code with VAG-Com to 'activate' the WFS right now.' I've never tried it myself.
Hi Dennis, Thanks for your quick reply!
Best regards, Achim
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the AFN control unit in an Audi A4 On-Board Diagnostics (OBD)
No new posts Injector Replacement: Audi A3 1.9 TDI Tips Diesel Engine Technology
No new posts Crankshaft bolt AFN: Always replace? Diesel Engine Technology
No new posts A3 (8P): Replace Turn Signal Bulbs Transmission, Chassis, Body & Interior
