A6 4B 2.5 TDI AGR limit exceeded
JanekA6
Post15-10-2009, 1:43    Subject: A6 4B 2.5 TDI AGR limit exceeded Quote
Hello, I did a engine swap on an Audi A6 2.5TDi, year 07/2003, from a BDG to an AYM engine, and the fuel injection pump worked fine icon_smile.gif.
"I've only just exceeded the EGR valve regulation limit. How can I fix this? Or does the BDG model have a different EGR valve?" Can anything be recoded there?
Best regards, Janek.
christians
Post15-10-2009, 12:49    Subject: A6 4B 2.5 TDI AGR limit exceeded Quote
The BDG (likely referring to a specific engine component) has a cooled EGR (Exhaust Gas Recirculation) system and a throttle valve to increase the EGR rate when necessary. Do you still have the BDG control unit installed?
Gruß Christian
JanekA6
Post15-10-2009, 12:56    Subject: A6 4B 2.5 TDI AGR limit exceeded Quote
Okay, the BDG engine control unit is installed, and I also have the throttle body from the BDG engine.
JanekA6
Post15-10-2009, 13:04    Subject: A6 4B 2.5 TDI AGR limit exceeded Quote
christians
Post16-10-2009, 11:22    Subject: A6 4B 2.5 TDI AGR limit exceeded Quote
Please measure the MWB 3, both with and without the EGR system activated, and check if the readings are reasonable.
Gruß Christian
New posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 575 limit exceeded Diesel Engine Technology
No new posts TDI PD Turbo: Overboost Issue & Diagnostic Log Upload
This topic is locked, you cannot edit or reply. Boost Pressure Control: Limit Exceeded Diesel Engine Technology
No new posts 16618 - Load Pressure Control Limit exceeded Diesel Engine Technology
