1.9 TDI 2V / 2.0 TDI 2V Exhaust Emission Warning Light P0101 16485 G70 (Solution)
dieselschrauber likes this.
Post27-09-2009, 11:06    Subject: 1.9 TDI 2V / 2.0 TDI 2V Exhaust Emission Warning Light P0101 16485 G70 Quote
Problem:
Check engine light is on. Event log entry: P0101 16485, Mass airflow sensor (G70), implausible signal. Additionally, a lack of acceleration may occur up to approximately 2200 RPM.
Reports have also surfaced regarding the addition of Diesel Particulate Filters (DPFs) later on.
Cause:
The oil filler cap has fallen off the pivot lever shaft. Due to the resulting oil loss, the oil pressure in the cylinder head decreases, causing the valves to only open partially.
Solution:
Remove the cylinder head cover and check if the aluminum plugs are present on both sides of each rocker arm shaft. If one or more plugs are missing, remove them from the cylinder head. Always replace both rocker arm shafts.
Translated on 11-07-2026, 21:57.
Ratings - 1.9 TDI 2V / 2.0 TDI 2V Exhaust Emission Warning Light P0101 16485 G70
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 3 - View ratings
No new posts 1.9 TDI 2V / 2.0 TDI 2V Exhaust Emission Warning Light P0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlikely Signal 16485-LMM: Log File Analysis Needed On-Board Diagnostics (OBD)
No new posts Exhaust Light: What It Means & How to Fix On-Board Diagnostics (OBD)
No new posts Golf IV Cabrio (1E) - Exhaust emissions warning light Gasoline Engine Technology
No new posts Golf TDI: When was the emissions light installed? On-Board Diagnostics (OBD)
