7D Heater: What is it?
Post29-09-2009, 20:23    Subject: 7D Heater: What is it? Quote
Hi.
What is
Address 7D: Heater Label file: DRV\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Part number HW: 1K0 963 235 E.
Component: PTC element 0404.
Revision: 00800000 Serial number:
Operating number: WSC 00000 000 00000
I always thought the PTC heater was directly integrated into the Climatronic system.
Was ist denn jetzt anders? War es früher (MJ06 im 3C) getrennt?
Translated on 30-09-2026, 12:31.
Octavia_4x4
Post04-10-2009, 10:54    Subject: 7D Heater: What is it? Quote
"For the years 2006-2007, it's listed as an external PTC heating element, located within the heat exchanger housing. There's also a note that says 'CLIMATIC - semi-automatic air conditioning system'."
Translated on 30-09-2026, 12:32.
Karma: +442 / -0   Thank you, like it!
Post04-10-2009, 20:10    Subject: 7D Heater: What is it? Quote
Updated in November 2006.
Previously, it was an external TCU (Transmission Control Unit). Later, two relays (for low/high heating) were used, which were controlled by the engine control unit.
Translated on 30-09-2026, 12:33.
Post04-10-2009, 21:52    Subject: 7D Heater: What is it? Quote
Interesting is...
Steht übrigens ein Vermerk dabei "CLIMATIC - halbautomat. "Air conditioner".
Because the scanned 3C model has a Climatronic system.
Definitely, it's the "glow coil" because I have the MJ07 3C and MJ08 1K installed.
Thank you.
Translated on 30-09-2026, 12:34.
Octavia_4x4
Post05-10-2009, 5:05    Subject: 7D Heater: What is it? Quote
Hello Martin,
Yes, I was also surprised to find the note about it, because you mentioned "Climatronic" above...
possibly, but also one of those errors that you sometimes find in various catalogs.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 7D - Auxiliary heater malfunction Electrical Systems, Vehicle Electronics, Multimedia
No new posts Auxiliary Heater Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Turn off auxiliary heater On-Board Diagnostics (OBD)
No new posts Activate auxiliary heater? Transmission, Chassis, Body & Interior
