DPF Delete & Performance Tuning
trebor
Post07-10-2009, 17:52    Subject: DPF Delete & Performance Tuning Quote
Hello!
I'm planning to retrofit a DPF (Diesel Particulate Filter) to my ASV (with 0.216 injectors and custom software).
Now the question is whether it's possible and sustainable, or whether I need to change or consider something else due to the increase in performance?
Translated on 22-10-2026, 2:57.
vwSchrauber
Post08-10-2009, 8:01    Subject: DPF Delete & Performance Tuning Quote
It is feasible, but the software should take into account that the back pressure in the exhaust system is slightly higher.
Ideally, you should use a DPF designed for a more powerful model. Unfortunately, this can then lead to problems with registration.
Expensive (and not entirely legal) solution: Buy a DPF for your model and a DPF for a more powerful model, have the one for the more powerful model installed, and get the installation certified. If you're lucky, no one will notice. You'll need to buy the "smaller" or "correct" DPF to obtain the necessary paperwork.
Translated on 22-10-2026, 2:58.
Post08-10-2009, 9:48    Subject: DPF Delete & Performance Tuning Quote
vwSchrauber wrote:
Expensive (and not entirely legal) solutions.
If I read this here
, ASV (0.216 inch nozzles + software)
, I would say that the tuning is probably not registered -> then the registration of the standard retrofit cap would not be a problem according to the official documents.
Translated on 22-10-2026, 2:59.
vwSchrauber
Post08-10-2009, 11:21    Subject: DPF Delete & Performance Tuning Quote
@ulfViewing profile: ulf: What do you mean by that?
The inspector will be able to see if there's a retrofit cap installed when the car is on the lift, but he's unlikely to disassemble the injector holders.
It is beyond doubt that both are forms of fraud, but from a technical perspective, a larger DPF would be advantageous with a corresponding increase in performance. Furthermore, the law is indirectly being complied with here, as the DPF intended for the car or the performance level would certainly be operating outside its most efficient range with the increased power.
Translated on 22-10-2026, 3:00.
Post08-10-2009, 12:19    Subject: DPF Delete & Performance Tuning Quote
vwSchrauber wrote:
@ulf: What do you mean by that?
The inspector will see that there is an aftermarket cap installed when the car is on the lift/pit, but he will hardly disassemble the nozzle holders.
For me, there are 2 main reasons for an aftermarket cap:
a) better nonsense sticker
b) Tax savings.
According to the filter manufacturer, tuned engines are not allowed to be tampered with -> meaning no registration, no valid inspection sticker, and no tax savings. As soon as you have a registered performance increase, but haven't reverted it to the original state, you'll face these consequences.
However, if the (visually undetectable) modifications are not registered, officials will not object, and you can enjoy the benefits of the "cork" modification.
And that's exactly what I assume when I read something about larger nozzles icon_wink.gif.
There is no doubt that both are forms of fraud, but from a technical perspective, a larger DPF would be advantageous with a corresponding increase in performance.
I agree!
Translated on 22-10-2026, 3:02.
No new posts Performance Boost: Increase Your Output Now! Diesel Engine Technology
No new posts 1Z to AFN Engine Swap & Performance Upgrade Diesel Engine Technology
No new posts DPF and Performance Tuning: Is it Worth It? Diesel Engine Technology
No new posts Lupo: Performance Tuning & Engine Upgrade Diesel Engine Technology
