AGR Clogging: Quick Diagnosis & Solutions
RennDiesel
Karma: +1 / -1   Thank you, like it!
Post23-10-2009, 17:54    Subject: AGR Clogging: Quick Diagnosis & Solutions Quote
After reviewing the old horror stories about deposits caused by the EGR system here again, I have a few questions, and I hope you are still willing to answer this annoying topic. icon_wink.gif
Is there a simple diagnostic method for my engine (BPW = Audi 2.0 TDI PD DPF) to determine its current condition? Or are endoscopes or specialized tools absolutely necessary?
Does anyone have experience with how long a cleaning process takes, or what it might cost (especially if I were to hire an independent workshop to do it)?
To my knowledge, the particulate filter (DPF) becomes clogged with ash, which cannot be broken down like soot and gradually clogs the filter (which is why the manufacturer only approves oils with low ash content). Does anyone have any idea whether deposits from the EGR system also pose a risk to the DPF?
Thank you very much!
Translated on 10-08-2026, 7:03.
Post23-10-2009, 18:32    Subject: AGR Clogging: Quick Diagnosis & Solutions Quote
The boost pressure hose is just clipped on; it only takes 1 minute to check it. icon_smile.gif
You'll need a larger flathead screwdriver for the retaining clip, and a combination pliers would also be helpful for gripping.
Translated on 10-08-2026, 7:05.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts Diagnosis On-Board Diagnostics (OBD)
No new posts KKL/KL Diagnosis: Causes & Treatment Diesel Engine Technology
No new posts VAG Diagnostics: Troubleshooting & Repair On-Board Diagnostics (OBD)
