Error code results + symptoms!
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
ventohaza_88
Post11-10-2009, 21:09    Subject: Error code results + symptoms! Quote
Hello!!
I drive a Vento TDI, engine code AHU, manufactured in 1997, with 235,000 kilometers on the odometer.
The following problem:
I recently got a VAG COM device to read engine data.
65535 - Control unit defective, error code 37-10 (and recently, it's showing error code 37-00).
00575 17-10 suction pipe pressure, control differential!
"After clearing the error code 00575 (the error code 65565, which indicates a defective control unit and cannot be cleared), and after another test drive, the 00575 error code no longer appears. However, if the vehicle goes into limp mode again, the 00575 error code reappears in the memory."
Approximately two weeks after the occasional misfires, another symptom appeared: a loud whistling sound.
No performance issues detected!
Please give me your advice!
goettmann
Post12-10-2009, 6:24    Subject: Re: Error code results + symptoms! Quote
That should overwhelm you with '575 + 1Z' icon_wink.gif.
Okay, ich bin bereit. Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
/viewtopic.php?t=4886&highlight=00575+1z
/viewtopic.php?t=15731&highlight=00575+1z
/viewtopic.php?t=15104&highlight=00575+1z
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error memory 1Z-TDI Diesel Engine Technology
No new posts Peugeot 206 and the error memory. On-Board Diagnostics (OBD)
No new posts Clear Error Codes: How-To Guide Diesel Engine Technology
No new posts Fault quantity setting in the fault memory On-Board Diagnostics (OBD)
