AAZ Engine Overheating: Causes & Solutions
LaurenzBo
Post17-12-2009, 20:15    Subject: AAZ Engine Overheating: Causes & Solutions Quote
This morning, after a long uphill stretch at full throttle (approximately 160 km/h), the ribbed belt on my AAZ engine broke. Fortunately, I noticed it immediately, and the next exit was only 1 km away, so I was able to coast there. The engine was quite hot from the climb, but the water temperature was still between 75-80°C thanks to the oil cooler. Since my family was in the car and we had an important appointment, I drove about 1 km to a workshop using as little power as possible. At one point, the temperature rose significantly, so I immediately turned off the engine and waited for a while before continuing. The coolant didn't boil, and neither water nor steam leaked out.
"At the workshop, they had a belt available and installed it. After that, the engine started perfectly again, and it ran smoothly for the next 300 km without any issues (no noticeable loss of power, although I only revved it up to about 4300 RPM). The oil is fine, but the engine noise seems slightly different above 4000 RPM (rougher), which might just be my imagination."
My questions:
Can a slipping ribbed belt (e.g., for the air conditioning or power steering) overload the timing belt, and should it be replaced as a precaution, especially since it has approximately 90,000 to 100,000 kilometers on it?
- The first candidate for damage caused by overheating is the head gasket; I already have the stronger version installed, and so far there are no signs of a blown head gasket or cracked cylinder head. I'll measure the compression soon. Is it possible that you might not notice a crack in the cylinder head initially?
- Are there any other potential damages that the overheating could have caused, and what would be indicators of such damage?
I hope the AAZ (charge air cooler and oil cooler, but not modified) survived that ordeal well...
Translated on 30-07-2026, 4:00.
BM
Avatar-BM
Post17-12-2009, 22:39    Subject: AAZ Engine Overheating: Causes & Solutions Quote
The oil is fine, but it seems to me that the engine noise changes slightly above 4000 RPM (becomes rougher), although that might just be my imagination
You could check if the belt drive is running smoothly and quietly. With this engine, the crankshaft pulley sometimes comes loose.
3B5 AJM
Translated on 30-07-2026, 4:03.
LaurenzBo
Post20-12-2009, 22:52    Subject: Timing Belt Sprocket Quote
No, I already know that issue - I already have the reinforced screw installed.icon_smile.gif
Translated on 30-07-2026, 4:04.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts AEL engine in T4 - Ex-ACV Diesel Engine Technology
